Old 08-01-2011, 03:18 AM
escar99 escar99 is offline
Rep: 10 Posts: 15
Freeboard for a small passenger craft
Hey, I am carrying out a project for a GRP construction passenger craft of less than 24m LOA.
I have found none english code from the MCA, or French rules applicable to that special vessels. Many rules make references to the load lines convention -which is not for vessels LOA<24m-.
Does anybody knows where can I find the freeboard value for passenger craft of less than 24m? I am from Spain, but any rule of other UE contry members would be of interest. Thanks!
Old 08-01-2011, 04:19 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1933 Posts: 3,025
There is the MCA small craft code, it is on their website (http://www.dft.gov.uk/mca/mcga07-hom...newsletter.htm)
As for freeboard. You make the freeboard high enough to pass the stability regulations...and then practical for boarding etc.
Old 08-01-2011, 05:11 AM
Rep: 10 Posts: 15
Thanks for your answer. However, all the SCV (small comercial vessels) codes do not allow craft which carry more thant 12 people...
Old 08-01-2011, 05:19 AM
Naval Architect
You have a serious amount to learn. This is very basic knowledge for any naval architect designing passenger vessels. ANY boat that carries more than 12 passenegers is a Passenegr Boat. This is defined in SOLAS...ie worldwide!
Old 08-01-2011, 06:05 AM
Rep: 10 Posts: 15
Sorry Ad Hoc, maybe I had not used the apposite terms.
My problem is that I can not find designing codes or rules for a GRP construction passenger boat of less than 24m, and operational zone near to the shore, except HSC -which allows them, but is not easy to satisfy for a 14m length boat, and non involved in an international course-
The only code which has a special article for this type of boats is the australian NSCV code. But in Europe, I have found nothing...
Old 08-01-2011, 06:21 AM
Naval Architect
My problem is that I can not find designing codes or rules for a GRP construction passenger boat of less than 24m, and operational zone near to the shore,...
I appreciate that English is not your first language, but you haven’t been very clear in your requests/questions at all. You started on freeboard now you’re on GRP construction!...which is it???
Use ISO in that case
(http://www.iso.org/iso/iso_catalogue...csnumber=40210)
Old 08-01-2011, 10:06 AM
Rep: 10 Posts: 15
Project Specifications
Thanks again Ad Hoc. I will try to define quite better the characteristics of the project I am carrying on.
14m LOA / GRP construction / 36 passengers / 2-5 Nm far from shore / National voyages / monohull
I am looking for a code or rule appropriate to that specifications. And I am specially interested on the value of the freeboard, so as to know if I can use a leisure craft hull for converting it into passenger craft.
Thank, and sorry for my english...
Old 08-01-2011, 01:19 PM
Rep: 3125 Posts: 9,408
Isn't there a similar thread about commercial GRP deviations in Spain, done recently (ISO 12215-1:2000)?
Old 08-01-2011, 02:43 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2069 Posts: 3,574
Small passenger vessels in Spain have to comply with an specific stability requirement:
With all passengers to the side in passenger intended spaces (deck) at a density of 4 (75 kg) passengers/sqm the vessel shall not heel more than 10 degrees nor submerge more than half of the initial freeboard.
You may also have a look at the 2010/36/EC Directive
Cheers.
Old 08-02-2011, 02:18 AM
Rep: 10 Posts: 15
Thanks, PAR and Guillermo.
About using ISO 12215; I think is just for leisure craft.
Old 08-02-2011, 02:48 AM
RAraujo RAraujo is offline
Naval Architect
Rep: 99 Posts: 52
For vessels involved in national voyages, other than those covered by specific instruments in specific regions/group of countries (like UE), you should consult with the national authorities.
For EU countries there is a specific directive for passenger vessels (all vessels acrrying more than 12 passengers) although not covering directly freeboard assigment issues (generally referring to ILCC66 which only covers vessels above 24m). This directive contains less demanding requirements for vessels engaged in more restricted operating environments.
Rodrigo
Old 08-02-2011, 03:10 AM
Guillermo's Avatar
Ingeniero Naval
escar99
I see you are in Banyoles, Spain. If the boat is intended to be flagged in Spain you should use the criteria in my previous post.
Ask your Capitanía.
Saludos.
Old 08-02-2011, 06:49 AM
Rep: 10 Posts: 15
Thanks for the comments!
Refering to my capitania -I hope you Guillermo have no relations there...- they make me satisfy a rule which talks about a freeboard of 450mm for a 12m LOA boat -too much!!-.
The hull that I have doesn't overcome that value... Moreover, that rule has been extracted from 1966 international convention on load lines, and my boat is less thant 24m, but they -capitania- also apply it.
That's why I am looking for an other country member rules. Administration in Spain is like my english... not very competent or serious.
Old 08-02-2011, 02:33 PM
Guillermo's Avatar
Ingeniero Naval
escar, I will send you a PM.
Cheers.
Small GRP Passenger Vessel amirhosein Boat Design 10 12-27-2008 11:37 PM
small passenger boat amohammadbeygi Powerboats 1 03-18-2007 08:13 AM
Small Passenger Boat amohammadbeygi Boat Design 7 03-12-2007 05:11 AM
small/fast passenger catamaran with ob motors Cristian Boat Design 12 08-30-2004 08:33 PM
SNAME Small Craft CD CDBarry Education 0 02-15-2004 05:06 PM
