Old 09-25-2009, 08:17 AM
mbhanoo mbhanoo is offline
Rep: 10 Posts: 13
Floating Canopy
Hi all, I'm designing a floating canopy to cover an object, which is 120m in length. Canopy is divided into no.of modules, in which each module consists of two box shaped pontoons of size 9m x 2m x 2m, which are spaced at a distance of 22m. Weight of each module is around 60T. The module's transverse stability is more since the breadth between pontoons is more. But it has negative longitudinal metacentric height. What can I do to make the module longitudinally stable other than increasing the length of pontoon and reducing KG. If the length of the pontoon is made 10m, then GML value is 700mm. I have one more question, GML positive value is enough for stabliity or is there anyr requirement for that? please answer.
Old 10-02-2009, 01:40 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
I'm afraid I'm not understanding what you want to do. Could you please post an sketch?
Guillermo Gefaell
Moon Yacht Design
Old 10-02-2009, 07:05 PM
Rep: 2891 Posts: 8,796
A classic example of a project in serious need of a qualified engineer.
Old 10-03-2009, 01:26 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
How high is the canopy? How much vindpressure to be expected at worst? VCG? etc.. Lot of guessing
Old 10-11-2009, 02:55 AM
kapnD kapnD is offline
Rep: 19 Posts: 142
I used to have a styrofoam sailboat that was extremely unstable, but the manufacturer offset the tendancy to capsize and turn turtle by the addition of a large styrofoam "beach ball" attached to the top of the mast. It didnt sail at all well, but was quite happy to lie on its side on its mooring.
I would like to have seen the design spreadsheet on that brainfart!
Floating dock mbhanoo Stability 8 07-08-2009 01:01 AM
1/4 inch Plywood canopy roof Bill57 Wooden Boat Building and Restoration 3 05-17-2009 09:14 AM
F-16 Canopy PetterM Powerboats 1 11-28-2007 09:34 PM
f-16 canopy... where to buy? Guest Materials 2 01-06-2005 10:47 PM
Plastic Canopy Archive Powerboats 1 06-12-2001 03:47 AM
