FishStretcher
I am considering fitting an anti roll tank tank to a small and somewhat tender cuddy style deep vee power boat. It has a fairly fine entry, a variable deadrise planing hull and a 26 degree deadrise at the transom. LOA is 24'10" (7.56m) and beam is 8 feet (2.4m) even. Displacement would be 4500 lb (2000kg) lightship, and about 6200lb (2800kg) fully loaded. Power is a single 300HP (225kW) counter-rotating I/O.
It is said this hull was designed for a bit more mass low and forward than it has. A NA who owns a few fitted them with add-on chines with a narrow tall air pocket to aid with stability at rest and the compressible air doesn't cause slamming, it is said.
It will cruise at a bit under 30knots and top out at about 40 knots.
The cockpit sole is below the rear deck by perhaps 8"/ 200mm and that continues into the cabin.
The cockpit sole is near full width, but short, fore- aft. 20"/ 500mm.
Standing in the cockpit, there coaming is about shoulder height. Perhaps 5 feet (1.5m)
With a narrow deep vee, it likes to roll at rest. It came with wooden boxes made to stand on on either side of the cockpit sole for shorter captains so the can see over the instruments properly. I think I can use these volumes for the two tanks of a passive anti roll tank system, with perhaps 13 gallons of water in 26 gallons total volume for about 100lbm/45kg or about 2% of displacement. (A guideline I found online.) If I fit the system with bilge pumps and filled with fresh water, I could empty them if necessary in an emergency or use the water for deck washdown.
This seems reasonable in scope to try to me, and removable if I want.
Has anyone tried such a system on such a small craft?
