Old 04-24-2012, 12:30 PM
mtht110's Avatar
mtht110 mtht110 is offline
T. Hoque
Rep: 10 Posts: 8
Fishing trawler problem
I have to calculate the capacity of fish hold for fishing trawler. Any one can tell me what is the density of fish. I calculate the volume but what is density of fish?
_t][t
Old 04-24-2012, 01:32 PM
Tad's Avatar
Tad Tad is online now
Boat Designer
Rep: 2143 Posts: 1,926
Density depends on the stowage method and fish species.....See STAB 4 appendix A of this document for some stowage factors......
http://www.tc.gc.ca/publications/EN/...HR/TP7301E.pdf
Old 04-24-2012, 01:57 PM
mtht110's Avatar
T. Hoque
Rep: 10 Posts: 8
Thank you bro
_t][t
Old 04-24-2012, 07:02 PM
tunnels tunnels is offline
old one !
Rep: 551 Posts: 3,778
Use the fish scale !!!!
Making beautiful boats is a passion never a chore !
Old 04-24-2012, 09:32 PM
mtht110's Avatar
T. Hoque
Rep: 10 Posts: 8
I'm very confused. So which density I've to use for my Fish hold capacity calculation. After calculation I've to approve this calculation from Classification Society. I here is no chance to mistake.
_t][t
Old 04-25-2012, 10:52 AM
Tad's Avatar
Boat Designer
What is the fish species? How are they stored in the hold? Is the the hold one large open space or individual tanks and is there any structure obstructing storage?
From the list in the link above........
Whole fresh Herring in bulk - 932 kg/m3
Whole Gutted fresh Cod in bulk - 793 kg/m3
Whole gutted fresh Cod in layered ice - 224 kg/m3
Frozen fillets in large blocks - 881-961 kg/m3
Frozen fillets in consumer pack - 400 kg/m3
Old 04-25-2012, 06:13 PM
TANSL TANSL is offline
Rep: 119 Posts: 476
You usually have fisheries in boxes 450x300x120 (or similar) with 15-18 kg each. Calculate the number of boxes that reasonably fit in the hold, discounting corridors, etc., and follows the load on it.
When fish is stored semi-alive in tanks the total weight is largely unchanged from the tanks filled with water.
Bring the fish in bulk in the hold will deteriorate dramatically fish and, therefore, in my opinion, you should rule out this possibility
Old 05-01-2012, 12:36 AM
rappitysnap rappitysnap is offline
Rep: 10 Posts: 2
I dont know if this helps but. I run a small operation 30' boat with a max of around 4000 pounds and when i build fish holds or boxes for mackerel, mullet, snapper. I figured for every 55 gallons of volume i can hold roughly hold 400lbs in a slush. if you calculate your volume and convert it to gallons you can get it pretty close
Old 05-01-2012, 12:48 AM
Previous Member
Rep: 0 Posts: 0
Fish have a swim-bladder they squeeze to compress the air within allowing them negative buoyancy.
Fish have slightly negative buoyancy.
Call it 1.05
Old 05-01-2012, 05:02 AM
Rep: 119 Posts: 476
Call it 1.05
We've all seen pictures of dead fish floating on the water surface. This suggests that a dead fish has positive buoyancy. ?????
The ease with which a live fish moves in water suggests that its apparent weight is very similar to the volume of water displaced. And it achieves this, in fact, thanks to its swin-bladder. (Buoyancy = 0)
Old 05-01-2012, 07:13 AM
hoytedow hoytedow is offline
Rep: 2142 Posts: 4,229
Here is some interesting information about the swimbladder. http://www.bio.davidson.edu/courses/...roduction.html
Hoyt
The TITANIC sank because it had a hole in it(still does). Submarine Tom
You just can't put too much info on your patterns. DGreenwood
Old 05-01-2012, 11:32 AM
midnitmike midnitmike is offline
Rep: 144 Posts: 244
Whenever I calculate fish hold capacity I've always used the density of sea water as my standard. This eliminates the need of knowing specific fish species, or how it's stored (dry, dry ice, slush ice, RSW, or blast frozen). The calculations are greatly simplified yet surprisingly accurate given the number variables one could involve.
MM
Old 05-01-2012, 11:42 AM
Previous Member
Rep: 0 Posts: 0
Good post Hoyt!
TANSL,
The question is "what is the density of a fish".
The answer is about 1.05
The density of water is about 1.0 at 4 degrees celcius.
Dead fish float because they gas up from rotting inside.
The OP may want to consider the space between the fish went transporting, what the fish are packed in, the container they are packed in, the type of fish, the density of the water they lived in, and many other variable which are far beyond the scope of his/her question.
Old 05-01-2012, 12:20 PM
Rep: 119 Posts: 476
What our friend MTHT100 needs to know is, not how much weights a fish, but the load it can carry in a cargo hold and under what conditions, the possibility of shifting of cargo, free surfaces and anything else that now I can not think.
I totally agree with MIDNITMIKE.
In any case I do not think it worthwhile to continue this discussion.
Old 05-01-2012, 01:05 PM
Previous Member
Rep: 0 Posts: 0
Sorry TANSL, that exclamation mark after your name was supposed to be a coma, my mistake, I had the cap lock on for your upper case forum name and forgot to take it off before hitting the coma botton which doubles as an exclamation key when on caps-lock.
I wasn't trying to express anger at your post.
If we want to read into what the OP is really wanting to know (a dangerous practice I've found) then I think a density of 1.0 should suffice and consider it water. Baffles may be a prudent feature to reduce free surface effect.
Modern fishing trawler lines plan Alfonso Boat Design 1 01-06-2011 09:55 AM
Net Drag on a fishing trawler harisankar Boat Design 8 03-24-2009 01:55 AM
38'+Fishing Boat/Trawler Wanted jesse l.t. Marketplace 7 06-30-2008 11:19 PM
new member here - fishing trawler building seafox Boat Design 13 04-29-2007 12:01 PM
36' fishing trawler in need of magic justplanecrazy Wooden Boat Building and Restoration 15 09-10-2006 08:21 PM
