Old 12-01-2011, 01:38 PM
BelgiumLearner BelgiumLearner is offline
Rep: 10 Posts: 8
Find Centre of buoyancy
How to find the center of buoyancy on a semi-submerged object?
Assume a square shaped barge with towers on both sides (PS & SB). Deck already submerged.
Can someone please give me a hint....
regards,
Old 12-01-2011, 02:05 PM
Rep: 1758 Posts: 1,561
Do it by parts, just like a constant density center of mass problem...
Old 12-01-2011, 02:12 PM
Rep: 10 Posts: 8
Thank you for your quick reply.
It does not ring a bell yet.... but i will try to find something about that problem....
Regards.
Old 12-02-2011, 01:52 PM
Rep: 10 Posts: 8
Maybe someone can post a link to material i can read about this subject?
Google is not my best friend .....
Old 12-02-2011, 10:31 PM
Rep: 1493 Posts: 7,447
The center of buoyancy is the same as the center of gravity of the submerged section of the body.
Old 12-03-2011, 03:02 AM
Rep: 10 Posts: 8
Absolute correct Gonzo, but i'm searching for an semi-submerged object.....
I responded to quick this morning.... it was stil early...
The center of buoyancy can be at the same location as the center of gravity.... then there is a indifferent stability. Most of the time you want the center of gravity below the center of buoyancy...
Old 12-03-2011, 10:25 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Center of buoyancy is the centroid of the submerged volume, whether the vessel is partially or completely submerged.
David Cockey
Old 12-03-2011, 10:28 AM
Rep: 10 Posts: 8
Thanks DCockey, but how to find it for a submerged body like described in the starting post
Old 12-03-2011, 11:16 AM
Engineer
Same as for a floating body.
Are you using software and the software doesn't seem to work for the particular configuration?
David Cockey
Old 12-03-2011, 11:41 AM
Rep: 10 Posts: 8
No... i'm just trying to find out how stability works on semi-sub rigs and/or barges....
Old 12-03-2011, 12:14 PM
Engineer
Basic principles are the same any floating vessel. Righting arm equals the horizontal offset between Center Of Buoyancy and Center Of Gravity. Static equilibrium is when COB and COG are aligned with one over the other. The equilibrium may or may not be stable depending on what happens at a small inclination angle. If the COB moves horizontally than the COG then the configuration is stable for small perturbations. If it moves less then the configuration is not stable for small perturbations.
Some of the assumptions used as short-cuts for ships may not be valid for other configurations. For instance the fore-aft stability may not be much greater than the transverse statibility.
David Cockey
Old 12-03-2011, 12:21 PM
Engineer
Do you know how to find the Center of Buoyancy for a "normal" type of vessel? If so what do you think is different for the configuration you described?
David Cockey
Old 12-03-2011, 12:24 PM
Rep: 10 Posts: 8
For a single hull ship, i use Simpsons rule. For a square i use 1/2 * draft.
Old 12-03-2011, 01:36 PM
Engineer
Use Simpson's Rule the same way as for a ship. Only difference is for submerged portions the top surface of the submerged portion is used rather then the waterplane, but that is the same as for a ship with a submerged bulb on the bow.
Any more specific questions?
David Cockey
Old 12-03-2011, 02:17 PM
Rep: 10 Posts: 8
Thanks David,
Will continue tomorrow....
Reserve Buoyancy Tevens Boat Design 41 04-14-2011 10:29 PM
centre of buoyancy question pilotdude Multihulls 10 07-08-2009 02:20 AM
buoyancy assesment Bluedesign Boat Design 1 07-13-2007 06:58 PM
Buoyancy vs Weight halfboat Boat Design 3 03-16-2007 08:55 AM
Centre of Weight Poida Open Discussion: All Things Boats & Boating 8 01-02-2007 08:59 PM
