Old 09-28-2007, 01:06 AM
janelove janelove is offline
effects of waves on ship stability calculation
hello,
I recently started learning about ship stability due to my studies. I understand that in ship stability calculations (assume good internal CG arrangements) , the main basis is that the righting arm moment need to be greater than the heeling arm moment (caused by the wind).... maybe I have not got to it but why the whole calculations does not consider the effects of waves?
Old 09-28-2007, 12:50 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
The righting moment has to be greater than the heeling moment whatever the cause: wind, waves, etc.
Navigate through: http://web.nps.navy.mil/~me/tsse/NavArchWeb/1/toc.htm
Very educating.
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 09-28-2007, 02:12 PM
Rep: 1623 Posts: 1,483
Originally Posted by janelove View Post
hello,
While, as Guillermo points out, the whole righting moment calculation needs to include water (wave) surface, the calculation itself can only be done as a static one. I.e. an instant in time. As it would be impossible to do all possible surface conditions for every roll position, certification societies and marine regulations usually specify a required Righting Energy (i.e. the area under the righting curve) be available. This takes care of the "three sisters" and other transient conditions (water on deck, etc.) of stability. See Chapter II of PNA, or Basic Ship Theory by Rawson and Tupper for a long discussion.
For where this concept breaks down see the SNAME paper "Predicting Complicated Dynamics Leading to Vessel Capsizing", a UNO paper on fishing vessel loss of waterplane capsizes I can't recall right now, and the MV Rocknes loss report.
Old 04-10-2008, 10:45 AM
gadfly gadfly is offline
Rep: 10 Posts: 5
jehardiman
What does "three sisters" mean ?
Thanks.
Old 04-10-2008, 01:46 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
"effects of waves on ship stability calculation"
here a page from Marchaj's book seaworthiness
Old 04-10-2008, 05:12 PM
charmc charmc is offline
Rep: 833 Posts: 2,390
Originally Posted by gadfly View Post
jehardiman
Thanks.
"Three Sisters" is a term describing a series of waves much higher than the average for the prevailing conditions. It's not precise, as waves much larger than the average can be alone, or in groups of as many as five or six, but a group of three is probably most common. The effect of three or more large waves in a row would be an extreme transient condition, but one which must be considered in stability calcs for a vessel to be suitable for operations in the open ocean.
Best,
Charlie
Old 04-12-2008, 11:16 AM
Charile is pretty much correct here. They are formed when the maximum amplitude of two wave trains of slightly different nominal periods are in sync. Similiar to the harmonic wow-WOW-wow-WOW sound heard when two engines are slightly out of sync, but as wave trains are comprised of a much broader spectrum, they appear infrequently.
They are so named for the three sister fates (the Moirae) of greek myth.
The first wave heels the ship (Clotho-who spins the thread of your life).
Before it can recover, the second wave knocks it on it's beam ends (Lachesis-who measures the length of your life).
And finaly, while knocked down, the third wave causes a capsize. (Atropos-who cuts off your thread of life).
Old 04-12-2008, 12:46 PM
Guillermo's Avatar
Ingeniero Naval
Guillermo Gefaell
Moon Yacht Design
Old 04-12-2008, 12:53 PM
Guillermo's Avatar
Ingeniero Naval
A different "Three Sisters"
Seahouses relief lifeboat "Peggy and Alex Caird" launches to escort fishing vessel "Three Sisters" into Seahouses in heavy seas 10/03/06.
Guillermo Gefaell
Moon Yacht Design
Old 04-13-2008, 08:59 AM
Rep: 10 Posts: 5
Now I know what the "Three Sisters" mean.
Thank you all.
Old 04-29-2008, 04:32 PM
Guest-3-12-09-9-21 Guest-3-12-09-9-21 is offline
Rep: 146 Posts: 154
http://www.youtube.com/watch?v=HhlNS3bOXBI
Not sure which sister this one was....but she sure was ugly!
--Chuck
Old 04-29-2008, 04:44 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
When those containers get overboard it's time of Atropos for a fin keeler..
Stability calculation of floating crane with the load broken off the hook pankguru4 Software 2 07-30-2007 08:20 PM
Cruise Ship Stability Willallison Stability 10 02-09-2005 03:09 PM
surface effect ship dynamic stability eos Boat Design 2 07-30-2004 06:56 AM
stability calculation Tim_Hastie Boat Design 1 06-14-2004 04:42 PM
Stability calculation sample from actually ship -tug boat...etc fadly2000 Services & Employment 3 05-22-2004 09:12 AM
