Old 05-20-2008, 03:39 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Downflooding angle
Allthough I don't have to, with my self engineered boatplans to get CE plates on the boat, I still like to do things properly. I've been now calculating STIX and got a question concerning DownFlooding Factor. What kinds of hatch/opening/companionway/door is considered secure or nonsecure in this regard???
I would also preciate the formulas for Roll Period and Roll Acceleration
Teddy
Old 05-21-2008, 07:06 AM
dskira dskira is offline
Rep: 1305 Posts: 1,363
You will find the down flooding in:
International Standard ISO 12217-2 reference number ISO 12217-2:2002(E) Small Craft- Stability and Buoyancy Assessment and Categorization
AnnexB (Page 29) Methode for Calculating Downflooding Angle.
The ISO booklet is not cheep, the 60 pages booklet cost $180.00 if I remember correctly. must be higher now.
Good luck
Old 05-21-2008, 07:29 AM
TeddyDiver's Avatar
Gollywobbler
Going to other thread Sailing boats' Stability, STIX and Old Ratios
It's allready about the subject..
Old 05-21-2008, 08:52 AM
So you just have just to buy the booklet and I will have the real thing since the CE regulation is ISO standard.
Good luck
Old 05-21-2008, 11:35 AM
TeddyDiver's Avatar
Gollywobbler
I'm trying to find out, if references like mentioned here, are included in the booklet or not, and do they contain any information about watertight doors. Nothing against buying books but in this respect I'm trying to find out which standard includes, if any, the information I'm looking for. So far it looks (by the names anyway) like the last one (ISO 11812) could be the one?
"2 Normative references
The following normative documents contain provisions which, through reference in this text, constitute provisions of this
part of ISO 12217. For dated references, subsequent amendments to, or revisions of, any of these publications do not apply.
However, parties to agreements based on this part of ISO 12217 are encouraged to investigate the possibility of applying
the most recent editions of the normative documents indicated below. For undated references, the latest edition of the
normative document referred to applies. Members of ISO and IEC maintain registers of currently valid International Standards.
ISO 2896:2001, Rigid cellular plastics – Determination of water absorption
ISO 8666:–1), Small craft – Principal data
ISO 9093-1:1994, Small craft – Seacocks and through-hull fittings – Part 1: Metallic
ISO 9093-2: –1), Small craft – Seacocks and through-hull fittings – Part 2: Non-metallic
ISO 9094-1: –1), Small craft – Fire protection – Part 1: Craft with a hull length of up to and including 15 m
ISO 9094-2: –1), Small craft – Fire protection – Part 2: Craft with a hull length of over 15 m
ISO 10240:19952), Small craft – Owner’s manual
ISO 11812:2001, Small craft – Watertight cockpits and quick-draining cockpits"
So are these in the same book?
Old 05-27-2008, 11:17 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
Teddy,
ISO norms are sold one by one, not in a book. You just have to buy whatever ones you need, but only those. Regarding cockpits and doors you need:
ISO 12216:2002 Small craft - Windows, portlights, hatches, deadlights and doors - Strength and watertightness requirements
To keep updated on the RCD you may be interested in registering here: http://rsg.balport.com/
Please find attached the last available version of the RSG Guidelines, which are of interest to apply the RCD.
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 05-28-2008, 01:06 AM
TeddyDiver's Avatar
Gollywobbler
I allready got the 11812 Just got to download some more. The RSG file is a good ref. Thanks Guillermo!
BR Teddy
Old 01-12-2009, 04:38 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
Teddy
where did you download, ? for us each euro is 2 dollars?
two right angle bevel toussy Inboards 1 04-07-2007 12:31 PM
Angle of Vanishing stability. Mychael Stability 37 08-31-2006 10:50 AM
Jib Sheeting Angle SuperPiper Sailboats 6 08-19-2006 04:59 AM
Relationship between angle of attack of keel and heel angle stelios Sailboats 9 05-29-2006 03:14 PM
What is transom angle? chase687 Boat Design 4 06-29-2005 02:21 PM
