| Dellenbaugh angle Is it that gives the amount the vessel will heel at 1pound per square foot of pressure? |
| Dellenbaugh angle is useful for comparing the sail carrying ability of similar boats. It has too many assumptions to accurately predict heel angle or to compare different types of boats. Comparing Dellenbaugh angles of a heavy displacement cruising boat and a light displacement racing boat would not be meaningful. |
| Thanks for that Paul.....so is there any better ways to accuratly predict the heel angle of a boat? If i kept the dell angle constant only varying the wind pressure, sail area and heeling arm. Would this be acurate in saying that the heel angle is constant? |
| dellenbaugh A small excel program for dellenbaugh angle Oktay Çemberci |
| Predicting the actual heel angle is difficult. When the heeling moment produced by the sails is equal to the righting moment at a given heel angle, the vessel is in equilibrium. The righting moment at various heel angles is not difficult to calculate, but the heeling moment is. Most stability criteria involving wind heel assume the windage is projected to a flat plane at the centerline of the vessel. Sometimes a cosine squared function is used to account for the reduction of heeling arm and projected area as the boat heels. This gives an approximation of the heeling moment, but it is not accurate enough to predict the heel angle in real world conditions. A designer has to rely on experience and careful comparison of stability data for known boats to reasonably predict the heel angle of a new design. |
| Paul, pretty cool |
| Thanks Daniel. I think boats should be cool ... like this one of yours: |
| The problem with many of those formulas is that they use formulas for static conditions. At different speeds the wave form changes. When the trough of the wave is in the middle of the hull (around hull speed) it decreases the floatation of that area. It means that the hull stability decreases. Tank testing and experience on a hull type usually prevent boats that become too tender at speed.
__________________ Gonzo |
I agree that experience by sailing on other hull is necessary, if you don't be to comfortable with your experience and just repeat the hull over and over, as do to many designer. The fear of mistake, well documented. A "formula" by experience is as detrimental. Cheers Daniel |
| I agree. But there are few really radical designs that work well
| I know what you mean Gonzo, and yes radical design are not always succesful. I was mostly talking designing boat out of the production line type, plain vanilla, boring with the same two triangular sail, no sheer, nothing to stop the eyes. Just corporate stuff, where nobody wrong, nobody right, nobody to take responsability. A sea of white crap with blue biminis, this is the sight of marinas today. No difference, no feeling, just the bad smell of bad barbecues the Sunday. That what I meant by lack of diversity, challenge and creation. Not automaticaly radical design, but different. Cheers Daniel |
| You can thank CAD for a lot of the crappy looking designs.It made the job of designing look-alike boats too easy. When you use a pencil and splines, being creative is part of the job.
| ce downflood angle | Guest62110524 | Class Societies | 15 | 05-03-2009 02:35 PM |
| Skid Fin Angle or not to Angle? | dcrummett | Powerboats | 2 | 06-11-2008 04:29 PM |
| two right angle bevel | toussy | Inboards | 1 | 04-07-2007 12:31 PM |
| Relationship between angle of attack of keel and heel angle | stelios | Sailboats | 9 | 05-29-2006 03:14 PM |
| What is transom angle? | chase687 | Boat Design | 4 | 06-29-2005 02:21 PM |
