I was wondering why you think it's too compromised by assumptions to make it useful? If the definition is actual heel from an equivalent 1lb/ft2 of defined sail area I would think it quite indicative. Surely the compromising assumptions are actually from the quick and dirty assesments of stability ( extrapolating low angle stability linearly ) then that's not being fair to Dellenbaugh ![]() These days it's easy to match an indicative heeling moment with a righting moment very accurately . It is a relative indicator of the power to carry the sail area the vessel boasts in it's SAD and as a quick rough and ready indicator I think it is hard to beat since SAD is close to useless on it's own.
You are right about being able to match an indicative heeling moment with a righting moment very accurately. I do think Dellenbaugh is a useful tool and I do use it in the preliminary design process. However, if you want to compare Dellenbaugh angle to older designs you need to use RM at 1 degree instead of the calculated righting moment at the Dellenbaugh angle. Dellenbaugh assumes sails are flat on centerline and wind pressure is directly from the side. Dellenbaugh makes no allowance for the reduction of heeling arm and projected sail area with heel angle. Because of these assumptions I would stick to comparing similar boats. Comparing the Dellenbaugh angles of a 30 ft sport boat and a 55 ft full keel heavy displacement cruiser would not be meaningful. Comparing a new design to a similar boat with known stability charicteristics is very useful. I agree SAD is close to useless because published displacement figures are rarely accurate, and the load condition at the published displacement is never available. That will skew the SAD figures into unreliable territory. |
.I agree it is for comparing similar sized vessels. I think it can be a really good indicator of the power you (might) be able to get from the rig. cheers Mike
| Dellenbaugh angle is just too simple to be correct. OK, it works as rough estimate. In terms of RM is does not work either. It uses metacentirc stability formula that is not accurate at 20-30 deg heel, does not consider reduction of stability as function of boat speed. If one needs to know real heel angle VPP is the way to go. |
1 - heavy cruisers; 2 - racer-cruisers (crew on rail); 3 - water ballasted boats; 4 - dinghies (crew on wire); 5 - multihulls; 6 - ULDB's. One can aslo note lines of achievable Froude numbers (displacement related) FnV. |
But is the quick and dirty GM method actually Delebaughs intent or just a practical solution in pre-computer days that became a normal way of assessing it? Surely now you we should always assess it from the static stability curve ? But I'm curious does anyone have the original proposition by Dellenbaugh that this was all based on, I've no idea where or when this came into common usage.
| ce downflood angle | Guest62110524 | Class Societies | 15 | 05-03-2009 02:35 PM |
| Skid Fin Angle or not to Angle? | dcrummett | Powerboats | 2 | 06-11-2008 04:29 PM |
| two right angle bevel | toussy | Inboards | 1 | 04-07-2007 12:31 PM |
| Relationship between angle of attack of keel and heel angle | stelios | Sailboats | 9 | 05-29-2006 03:14 PM |
| What is transom angle? | chase687 | Boat Design | 4 | 06-29-2005 02:21 PM |
