Old 12-21-2010, 10:39 AM
erdeminanc erdeminanc is offline
Rep: 10 Posts: 3
cross curves of stability
i need a simple excel worksheet for calculating GZ (righting arm).
i have the offset table of a ship and 15,30,45,60 degree offset for immersed position for transeverse stability.
appreciate your help, thanks.
Old 12-22-2010, 12:45 PM
Rep: 10 Posts: 3
it's really urgent, please help.
Old 12-22-2010, 01:25 PM
Rep: 1493 Posts: 7,447
It is not simple.
Old 12-23-2010, 05:32 AM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 323 Posts: 523
download Freeship and hydrostatics extensions for it. It is free
Hull shape import, if you do not need fairing, is a matter of "spend a few hours to read the manual and it is a job for a few minutes". Table of offsets simply has to be a text file of certain structure. All the rest is easy.
All the stresses in my designs are 95% of permissible.
Old 12-23-2010, 06:28 AM
Rep: 10 Posts: 3
Thanks.
I have the program, Freeship, but unfortunately, i couldnt find the extension that you stated.
Could you please give a link for the hydrostatic extension for freeship?
Old 12-23-2010, 06:59 AM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 485
Yet another late and desperate NA student. What do you think these home works are for? If you cant get over these exercises without forum help, how can you get over your real work in future?
Only shared knowledge can grow.
Old 12-23-2010, 07:11 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Again, it's not that simple. The reasonably well validated cross-curves module is a plugin for Delftship Pro, and it costs money. The built-in one in Freeship (as found on sourceforge) and Freeship+ is, shall we say, less than perfectly accurate for some hull forms.
It certainly looks like the question is a school assignment, and as a general rule, folks around here aren't too keen on doing students' homework for them. Freeship isn't the only software that can do this, but I doubt the question is "plug in these numbers and see what happens"- more likely it's "prove that you understand how a righting arm curve is computed".
Old 12-24-2010, 03:43 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 265
Better you should prepare it by yourself. Take the book "Theoretical Naval Architecture" By Attwood .. and start reading from page 158 there are three method is given in that chapter, i will suggest you the Barne's Method to study and prepare the excel worksheet ... take help from you teacher too.
it's not so simple work but once you can understand for one degree , you can do it for others too. You may also need to use Autocad .
DAre To DreAm
Old 12-24-2010, 08:52 AM
Rep: 323 Posts: 523
Thanks.
Sorry, no info on this. I use Delftship. It is not free, and my boss will not share it...
Old 12-25-2010, 06:00 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
I'm using Freeship 2.6 and it's in Calculations -> crosscurves. It should pop up a dialog box for the inputs.
Maybe you can explain what the heck these curves mean
Old 12-25-2010, 06:06 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1933 Posts: 3,025
See here:
If you still don't understand, may i suggest you read a book on naval architecture as you're out of your depth.
Old 12-26-2010, 03:02 AM
Alik's Avatar
Alik Alik is offline
Rep: 1070 Posts: 2,036
It is easy to get those curves by series of stability calculations, by any software even not having this 'cross curves' function. Just need to look at 'stability mechanism'...
Old 12-26-2010, 07:29 AM
cthippo's Avatar
Rep: 452 Posts: 725
Originally Posted by Ad Hoc View Post
See here:
Attachment 51630
No question that I am. I replied because I downloaded and was playing with freeship last night and noticed that feature.
Old 12-30-2010, 08:16 AM
ngyen ngyen is offline
Rep: 10 Posts: 12
yes .. i think so.. i made an excel sheet by following those rules,, but i think i need to search for that sheet again.. many days ago i did it
Old 01-07-2011, 05:19 AM
adek adek is offline
Rep: 10 Posts: 4
Erdem contact with me .I can help ypu
Freeship Discussion Regarding Cross Curves Calculation EAP Software 8 06-10-2010 03:44 AM
Cross Curves in Freeship lewisboats Software 1 10-13-2009 11:16 PM
creating hull cross-sections from bonjean curves? hmcs Boat Design 7 03-11-2009 11:08 AM
Cross Curves of Stability for tanker - please help! ajantas Stability 2 05-13-2008 08:20 AM
Can rhinomarine cauculate Cross curves of stability? bbsboat Software 7 10-09-2007 02:57 PM
