| crazy 30meter beam stability question hi all, imagine this:
let's exclude the superstructure.... what stability issues would it encounter (many i am sure), but what exactly? how do you counter them? would you need a deeper draft? thanks! |
| you are talking about a hull with length to beam ratio L/B=2.0 if this is a monohull it sounds more like a barge than anything else. You dont mention the speed but unless it is designed to plane i dont think it will have stability problems. |
| Remmber that the hull is basically 2 triangles put together, joining opposite to each other. So one triangle facing west with hight 19 and base 30. The other triangle facing east with hight 43 and base 30. Both starting at the same point. How would you advise the hull below LWL be formed? The impact with the on coming hydrodynamics would generate much friction, right!? So, what do ya think? |
| Let me get this straight. The thing is more or less diamond shaped when viewed from a helicopter, and is twice as long as it is wide? Sounds more like a hydrostatics professor's idea of a bad joke than an actual boat. Could you try posting a sketch of what you're thinking of, to confirm that it's really as strange as it sounds?
| No sketch needed, it's exactly what it sounds like. A diamond shape (exactly). But it's not a joke, see it more as a way to understand designers thinking outside of the box and normal conceptual designs. How would you reach maximum stability on such a design? And maximum fuel efficiency? Thanks! |
| Hmm. For maximum initial stability in something like that I think I'd want as much buoyancy out at the perimeter (especially the tips of the short axis) as possible; ie. a fairly squared-off bottom shape. Since it's pretty close to the least efficient planform I can think of in terms of drag and fuel use, optimizing fuel efficiency would be best achieved by having it stay still whenever possible. If it has to move, that's another story. Perhaps a run in Michlet will reveal a point on the speed/drag curve where the bow , mid and stern wakes (I'm pretty sure it will create a secondary wake at the sharp corners, as well as the normal bow/stern wakes) manage to partially cancel out; this would be its ideal cruise speed.
| I agree on the secondary wakes. What if the beam points where rounded instead of being pointy?...would the wake be less turbulant? What is Michlet? Is it along the lines of maxsurf seakeeper or autohydro? |
| picasso, Somebody recommended you the reading of Gerr's "The Nature of Boats" at the other thread on this 62 m yacht designing of yours. I friendly and strongly support that reccommendation. Most educative and entertaining reading. I think you will enjoy it a lot as well as get from there many claryfying concepts (Well, there are some things I do not totally agree with, but my overall opinion is frankly positive for a divulgative book like this). Cheers!
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
| Thanks mate. I guess I'll give it a read before posting more. ![]() |
| I recall, there was a recent post and commentary involving a diamond-section keel with the sharper end forward. A skinny version of Picasso's idea. A. |
| Does it have to be a mono hull? You could make this about as efficiant as it gets and square (more deck area) AND stable if it were a catamaran. Just my 2cents |
| Going back a few posts- Michlet http://www.cyberiad.net/michlet.htm is a useful little program courtesy of Leo Lazauskas which can give pretty good estimates of hull resistance and wake properties, within certain limits of geometry and speed. Whether it would work on this diamond block of yours- it would certainly try, but the results won't be the most reliable, I think because the water flow is going to be completely turbulent and utterly unpredictable aft of the pointed wings. The format and interface are a bit tricky to get used to but are actually quite efficient.
| Thanks guys! (I much prefered the sheldric's morphogenetic field version). The idea is to keep it as a monohull. But it is not necessary to keep the wetted surface "diamond" shaped. The top view needs to remain original though. I'll give Mitchell a try, and see how it compares to the other 2. Thanks for the tip! |
There will have to be some very strong overiding reason to go with a hull this shape, ease of fabrication and cost definitely don't justify the fuel cost of operating a vessel with a hull like that. What is the application supposed to be? |
| Catamaran beam vs trimaran beam | seadog1970 | Multihulls | 11 | 08-19-2007 05:49 AM |
| Crazy question?? | rawley2 | Software | 8 | 06-20-2007 10:53 AM |
| Rough seas stability: wide or narrow beam? | glastront156 | Boat Design | 12 | 02-18-2006 12:39 PM |
| Book recommendations, and a simple question. Am I crazy? | jstcrzyengh | Fiberglass and Composite Boat Building | 4 | 09-07-2005 04:35 PM |
| For those who think they are going crazy... | Sean Herron | Boat Design | 2 | 10-23-2004 01:42 AM |
