Old 04-14-2010, 11:33 PM
evantica's Avatar
evantica evantica is offline
Rep: 42 Posts: 127
concrete
I have a "space" that's gonne be hard to rust protect. I "heard" to pour some concrete there will eliminate the rust in the future???
This concrete will be in a closed space far down in the keel section.
Old 04-15-2010, 02:26 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
If the concrete sticks to the steel tightly and stays stuck, you might be okay. If the concrete doesn't stick or is knocked loose, you'll be in more trouble you started with.
Hopefully creating something useful, since 1983.
Old 04-15-2010, 04:00 AM
evantica's Avatar
Rep: 42 Posts: 127
Lurvio, thanks! The "place" I wante to pour it in is a totally closed part of the keel! My thought was, to make the concrete so thin, and then pour it so it filled the "closed box" entiery and then seald(?) the "filling hole". Would this -in a long term -be a problematic place???
Hakan
Old 04-15-2010, 06:37 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Keep it simple
The better solution is to seal the void with plate welded to keel with threaded socket and plug fitted on filling hole. Go to any auto repair shop and get some old used oil - they would gladly give it to you free of charge just to get rid of it.
Pour that into the void and screw close the plug. No way you will have rust from the inside after that and there are no side "effects" you may have with cement that will happens.
BTW, I sealed all the voids in steel keels this way whilst building steel boats...
Wynand
A scatterling of Africa
Old 04-15-2010, 07:34 AM
evantica's Avatar
Rep: 42 Posts: 127
Great ide' wynand! thanks.
Old 04-15-2010, 08:34 AM
DrCraze's Avatar
DrCraze DrCraze is offline
Rep: 20 Posts: 91
I work with cement every day and advocate its use often, however I would advise against this. Soupy concrete shrinks considerably unless you use some serious admixtures and even then you would experience some delamination on large panels. I say fill it with tar
Old 05-18-2010, 07:22 PM
dskira dskira is offline
Rep: 1305 Posts: 1,372
I will go with Weynand and Craze.
I prefer personaly tar, but saw good result with oil too.
We did the oil on life boat cavities. We did the tar on fishing boat cavities.
So choose your poison
Daniel
Old 05-19-2010, 04:45 PM
Rep: 1493 Posts: 7,447
Concrete will probably let humidity through and create a lot of corrosion. Hot tar is a better product.
Old 05-20-2010, 12:22 PM
jonr jonr is offline
Rep: 34 Posts: 246
I wouldn't use anything that could harden and pull away. Maybe very soft tar or very thick oil.
Old 05-20-2010, 05:42 PM
capt littlelegs capt littlelegs is offline
Rep: -67 Posts: 237
Concrete is a traditional method of filling voids permanently and reacts well with steel, often used as repairs over rivets and welds or damage in ships. Old barges often have complete concrete bottoms in the bilge. It needs to be a proper mix rammed or vibrated in and the edges sealed later to prevent damp from getting in the thinner parts.
Old 05-20-2010, 05:56 PM
apex1
And it needs to be removed after some years.....................
....which is quite a task.
I have yet to see a vessel where the concrete did not separate from the hull causing extreme problems.
Unfortunately 6 or 7 of my museums ships had sustained such a dumb treatment, and all needed some serious repairs on frames and plating after the cr@p was removed.
So, I was there, have done it, got the T shirt!
Leave concrete out of cavities.
Regards
Richard
Old 05-20-2010, 07:21 PM
Rep: -67 Posts: 237
Regards
Richard
Not so, Dutch barges for one have used it for as long as steel has been used. You have not seen my own Dutch barge that still has the shaft set in original concrete, ninety years old and still in excellent condition. I tried to remove some concrete in the bilge, nothing wrong with it but it was so tough and attached that I would have damaged the steel in getting it out. Poor concrete or thin infills over wood may not last well but they just break up without damage, if it separates, and there's no reason why it should, then it would be easy to get out! You make up negative scaremongering stories about many things and certainly don't know everything but I'm still there, still doing it with plenty of tee shirts!
Old 05-20-2010, 07:47 PM
Perhaps you are right for your barge, but do not underestimate Richard, his knoweldege is deep and he do not say things just for the sake of it.
read his posts, it is interesting and we all learn from him.
Daniel
Old 05-21-2010, 03:31 AM
Rep: -67 Posts: 237
Daniel
I have seen these debates many times before, what is best depends on the particular situation but concrete is tried and proven and should not be dismissed out of hand by biased opinion.
Sorry but I do not share your blind puppy faith in Richard, he says things for the sake of argument and reaction, if his knowledge is deep it certainly isn't wide so he adds ********, this still leaves a mess that must be discarded.
Old 05-21-2010, 06:20 AM
Why you insult me, are you that insecure?
Having a friend who I like very much and is a great person, do not make me a puppy, but a human being, which you seams not gasp the principle.
You are the ********, I try to help. Go back to your ignorance captain little penis.
Daniel
Concrete submarine waterchopper Boat Design 852 12-10-2009 03:55 PM
Concrete Canoe! (Help) Luciano Boat Design 13 06-13-2009 04:44 PM
Ballast- concrete beam Ari Wooden Boat Building and Restoration 12 02-20-2007 07:37 PM
Barge Out of Concrete? Hotel Lima Boat Design 21 12-12-2006 02:27 PM
Design of a concrete canoe fmechini Software 1 02-21-2002 11:52 AM
