| catamaran hydrostatic calculation hello, anybody has a manual hydrostatic calculation sample for a catamaran yacht in excel format? I need some good reference. I couldnt understand well how to do it since i've only knew some for monohulls... Please help thanks!..
__________________ --amateurs built the ark, professionals built the titanic-- |
| By deduction I think so: I: Moment inertia of single hull Then: I(cat)= 2 x (I x (beam/2)^2)= I x beam^2 / 2 Regards. |
| Everything is the same, you just have to calculate the waterplane inertia properly. http://en.wikipedia.org/wiki/Parallel_axis_theorem So to correct the equation above Ixx (cat) = 2*Ixx(ama)+2*Awp(ama)*(distance between ama CL's/2)^2
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
Thanks for this reply. May you please be specific of the ff. legends u used in the formula stated? Ixx = ? ama = ? CL = ? Thanks a lot and advance happy new year! Best Regards, Joyce
| ama is one hull of a catamaran ama CL is centerline of an ama Ixx is moment of inertia about the x axis. Location of the x-axis is noted in paranthesis
__________________ David Cockey |
| i believe before asking such questions TS should adjust his signature ![]()
__________________ http://albatrossdesign.livejournal.com |
| I think the following link can help to get some idea :- http://en.wikipedia.org/wiki/Displacement_%28ship%29 |
| Resistance calculation and propulsion calculation for tug boat | sreejith | Props | 0 | 02-06-2010 03:43 AM |
| Hydrostatic Data from Rhino 3.0 | Kirkos64 | Software | 0 | 12-20-2009 07:09 AM |
| Motor sailor catamaran rig calculation | Boris ypd | Motorsailers | 0 | 03-21-2009 12:17 PM |
| Help!!! Regarding with the Ship's Hydrostatic Calculation... | kilbysg | Boat Design | 0 | 04-10-2008 09:12 PM |
| hydrostatic in rhino 3 | Ahmed Wahab | Software | 7 | 12-27-2007 03:02 PM |
