Old 02-12-2007, 07:04 AM
gbr43926 gbr43926 is offline
Rep: 10 Posts: 7
Canting keel lab experiments?
Hello everyone,
Since i first saw a canting keel and CBTF technology in action it has amazed and excited me...
~So much so that ive began a small investigation just for my own interest.
Ive been looking at the existing mechanisms in place on such vessels as the VO60 and V070 (hydraulic systems) and comparing them to designs such as the Backman canting system (pulleys).
I understand there have been Material issues with the hydraulic systems which ultimately caused failure> 2 ram rod failures and 1 ram end cap failure in the Volvo Ocean Race. Which has caused much debate in the technology. Was this simply wrong material selection? or was it down to faulty materials?
Im interested in undertaking some simple experiments which would help me to understand the effects of using a canting keel compared to a fixed keel.
I have thought of some simple moment calculations which would allow me to calculate the difference in displacement, righting arm etc.
I want to be able to show what sort of performance increase a canting keel will provide.
If anyone has some simple tests/ experiments or even just opinions then i would be most grateful to hear from you..
Many thanks
Old 02-12-2007, 07:33 AM
Doug Lord
Cbtf
From some conversations I've had with couple of the CBTF guys they expect a 30-40% reduction in displacement for the same righting moment as compared to a fixed keel. Thats with a 55° canting keel. You might write to Bll Burns at CBTFco....
Old 02-12-2007, 07:47 AM
Rep: 10 Posts: 7
re:cbtf
Wow thats am impressive reduction! looking at the backman 21 for example, which cants approx 43 degrees; the bulb weighs 225kg
the total displacement of the vessel is only 520kg!
so a reduction in bulb weight of about 40% would be quite a significant displacement reduction in this vessel, this boat must plane really easily!
Old 02-12-2007, 03:10 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
Have a look at its stability implications in the attached document.
Cheers.
Guillermo Gefaell
Moon Yacht Design
Old 02-12-2007, 03:50 PM
Rep: 10 Posts: 7
re:
thanks! think ive looked at this document before, the righting arm curves look impressive! at 10 degrees heel, the righting arm for the canter is 3 times what it is for the fixed keel. i suppose this means it will hold 3 times the power? incredible!
even at 30 degrees heel, the canter holds 60% more power than the fixed keel!
thanks for the replies
Old 02-22-2007, 07:45 AM
Rep: 10 Posts: 7
Righting arm experiment
I have been advised to do an experiment which will help determine the righting arm achieved with different ballast systems.
the idea is to build a scale model of a particular hull which is suspended along its COG
> have the hull sprung so that it is at rest at an angle
model keels can be attatched to the model to show the righting angle they achieve
also the weight reduction for a canting keel can be calculated
any thoughts?
cheers
90°-110° Canting Keel Doug Lord Stability 14 12-17-2006 08:36 PM
Canting keel tamkvaitis Sailboats 3 01-08-2006 09:03 PM
canting keel opinions nemo Boat Design 22 09-02-2005 09:33 AM
why canting keel? freemanjunelee Sailboats 18 06-06-2005 05:37 PM
Canting Keel Design MrK Sailboats 28 03-19-2005 08:22 AM
