| Can Maxsurf Calculate Bojean's curves? I wonder: Can maxsurf softwares be use to calculate Bojean's curves? Sometimes, Bojean's curves is needed in Ship design...
__________________ I Am not a Ship Designer! But a ship player. |
| you cant get Bonjean curve from maxsurf. BUt u may get the data from Hydromax as it is mention here in the FAQ http://www.formsys.com/support/knowl...Vs1mGxcBUDnaWw From that Webpage : " There is no direct method of bonjean calculation in Hydromax. However it is possible to get sectional area data at selected draughts: 1. Run an upright Hydrostatics calculation at the required draught and trim. 2. Go to the results table. 3. Select each draught in turn and choose "Display | Select view from Data" 4. Then go to "Window | Graph | Curve of Areas" -- this will bring the curve of areas to the front instead of the upright hydrostatics data, and is only required the first time. 5. Double click anywhere in the graph window to get the data table. 6. Copy and paste the first two columns into a spreadsheet. 7. Then close the dialog, go back to the results table, select the next draught, select "Display | Select view from Data", go back to the graph, double click, select, copy and paste the data -- repeat for each draught. Tip: If the windows are not maximised, you'll find it easier to switch between the results table and sectional area graph."
__________________ DAre To DreAm |
| Oh, thanks. I noticed that. It's very helpful. I can calculate the area of each section. But sometimes, area moment of each section is included in Bonjean curve. Then, how to finish this job?
| Help me calculate | Wemdoug | Metal Boat Building | 5 | 12-17-2009 12:48 PM |
| Making Curves - is this one way? | kach22i | Fiberglass and Composite Boat Building | 35 | 06-02-2008 04:44 PM |
| Rhino Curves | jmedick | Software | 6 | 06-27-2007 01:34 PM |
| Maxsurf: lenght of curves | Red at Night | Software | 3 | 08-11-2005 04:46 PM |
| Ships Curves | Boat Design | 1 | 10-01-2002 10:05 PM | |
