Old 05-07-2010, 09:41 AM
naupigos_gr's Avatar
naupigos_gr naupigos_gr is offline
Rep: 11 Posts: 31
Calculation
Hello, I have a pre-design project for my university.
I have to calculate main dimensions and coefficients of an LNG tanker with capacity of 145.000 cu.m., and speed 20 knots.
I found a list of similar vessels but i got lack of parameters in many vessels, such as Displacement.
Without the parameter of Displacement i can not design a curve through Regression analysis.
I tried many different web sites, like vesseltracker..
Is there any practical way, to calculate Displacement?
thanks john b.
Old 05-07-2010, 11:35 AM
Rep: 1758 Posts: 1,561
Why not do it the old fashioned way....Lay out the cargo holds, add an engine room, and then draw a hull around it. If this is for a school design project, you should have been taught all the tools and concepts you need.
Come on, this is not a time to copy, this is a time to have fun with design and self expression because there is no "correct" answer. You only need to show that you understand the concepts of design trade-off.
Old 05-07-2010, 02:50 PM
Rep: 11 Posts: 31
yea, okay...
but working with 19 vessels or more it is hard to draw 19 different plans
thanks anyway...
Old 05-08-2010, 01:06 PM
JRMacGregor JRMacGregor is offline
Rep: 245 Posts: 78
Typical block coefficient for that size of LNGC is 0.67 to 0.72. That works for speeds in range 18.5 to 20.5 knots.
With the CB and the main dimensions you can work out the displacements of your hulls.
Old 05-08-2010, 05:54 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,359
Why don't you start with the size and number of holding tanks needed, then design the ship around that?
Hoyt
Old 05-10-2010, 12:37 AM
conceptia's Avatar
conceptia conceptia is offline
Naval Architect
Rep: 97 Posts: 193
naupigos,
Please refer to Practical ship design by Watson.. It gives you empirical formulas to fix your main dimensions. Remember one thing, your final displacement will have a reasonable change with the priliminary, so be conservative on primary fixing of displacement. You can also refer PNA, and Ship design for efficiency and economy by Schneekluth.
All the best for your project.
Cheers
Aswin
"Aim of any argument or discussion must not be victory, but progress."
Old 05-18-2010, 02:36 AM
ejim ejim is offline
Not Really Junior Member
Rep: 10 Posts: 8
Your question is how to calculate displacement, right?
here the formula : L x B x T x Cb x (density of water)
Old 05-20-2010, 04:56 AM
Grant Nelson Grant Nelson is offline
Rep: 159 Posts: 203
You can get a free trial at http://www.ships-register.com/
Maybe that will have what you need...
Old 06-04-2010, 04:07 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
$1130 is the minimum registration fee on that site? Geeee!
Old 06-04-2010, 05:08 AM
conceptia's Avatar
Naval Architect
Rep: 97 Posts: 193
nelson, ship register dont provide free trial as of now. I did try for that 2 months back, but they told cannot give a free trial.
Cheers
Aswin
Resistance calculation and propulsion calculation for tug boat sreejith Props 0 02-06-2010 03:43 AM
Chainplate calculation brucechu1228 Sailboats 0 01-27-2009 02:26 PM
Calculation of GM Shidoran Boatbuilding 14 04-25-2006 03:19 AM
Speed calculation!!! bing2005 Electrical Systems 0 01-27-2005 02:28 AM
stability calculation Tim_Hastie Boat Design 1 06-14-2004 03:42 PM
