| calculating heal can any one help. I'm trying to calculate what wait is needed for a 14 ft sailing dingy, and weather I need a trapeze. the formula that I'm using is, the force in the sails x the hight of the CE x the depth of the CLR x the force against the dagerboard. but is there any set wind force used in this equation. and is the force on the dagerboard = the force of the wind? thanks for any help you can give me. cheers |
| You need to substact the force created by the stability of the hull
__________________ Gonzo |
| thanks for the reply gonzo I am currently working to get a place at a university to study marine architecture, and this is sort of a project to show them. as I have no training in this field I am very sketchy on the theory behind all of the analysis work. one problem that I'm having is that this is a sailing dingy and will no doubt be top heavy, relying on the crews wait to keep her upright. does the stability of the hull + rig still play a roll in the equation when there is no self righting factor ( waited keel or ballast). this design is very similar in shape to the Merlin rocket. if that helps at all. thanks for all your help cheers |
| There will be some initial stability. That is why the boat can float upright without a crew. It isn't much though. The easiest way to know if you are on the right track, is to look at dinghies that have or not trapeze. See what your calculations show for each.
| is this something that is used allot in dingy design? or is it more common to guesstimate for smaller boat such as this. as there as lots of variables that can play a part on a boat this size. |
| Calculating risk | watchkeeper | Boat Design | 15 | 11-01-2009 12:15 PM |
| Calculating Bevels | ajmoir | Boat Design | 28 | 12-05-2005 04:49 PM |
| Calculating the speed | huntermike32 | Propulsion | 27 | 11-14-2005 02:39 PM |
| calculating GZ | UNOSNAME | Boat Design | 6 | 11-04-2004 05:06 AM |
| calculating displacement | 8knots | Boat Design | 2 | 03-21-2002 01:57 AM |
