Old 09-10-2009, 02:09 AM
Boston's Avatar
Boston Boston is offline
Rep: 1360 Posts: 3,257
calculating dynamic stability
Im trying to better understand the parameters that go into improving dynamic stability and Im not finding much literature concerning boats
some things are obvious like mass and buoyancy distribution beam to length ratio and the like but
what is the magic formula
I cant find it anywhere and its not in my wiley engineers desk reference
thanks
B
Old 09-10-2009, 07:30 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,692
Define improving?..and what does 'dynamic stability' mean to you?
Old 09-10-2009, 08:21 AM
stavrou2000 stavrou2000 is offline
Rep: 10 Posts: 24
Please Explain Better...dynamic Stability..about What? What Is The Force...is It Wind?gust?beam Waves?...if You Dont Know The External Force How Can You Define The Dynamic Stability Equation?
Old 09-10-2009, 11:41 AM
Boston's Avatar
ya that was a poorly phrased question
Im considering a 60' motor yacht semi displacement hull with a 12' beam, 42"~48" draft, displacement of about 21 short tons, engines of about 2400lbs ttl, typical fuel load of about 3 tons
Im most interested in playing with weight distribution, beam and draft in order to gain some advantages in stability in various sea states
wind I will factor in at some point but one thing at a time
I though Ild start with wave energy
there is something referred to as the "Dynamic Stability Factor" I keep bumping into as I look into seaworthiness issues and Im dam curious as to how this is calculated ( rumor is I want this number to be about 40 for a blue water cruiser )
that way I can possibly tweak a few things still get the look Im after and a safer boat all around
Old 09-10-2009, 12:20 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2006 Posts: 1,639
Dynamic Stability Factor (FDS) is from the ISO stability standard and is used in the calculation of the STIX (Stability Index) number. You'll find much discussion of STIX on this forum.
For sailing yachts using metric units (See Principals OF Yacht Design)
FDS = Agz / (15.81 * sq rt Lh)
Agz is the area under the righting arm curve up to the downflooding point.
Lh is the hull length as defined by ISO standard.
FDS will be something between .5 and 1.5 (again metric units)
STIX will be something between 20 and 60-70 perhaps.
Old 09-10-2009, 12:24 PM
Boston's Avatar
Dam
I have got to order that book
I get another nice draw tonight so Ill order that soonest
thanks Tad
B
Old 09-10-2009, 12:44 PM
Alik's Avatar
Alik Alik is offline
Rep: 1020 Posts: 1,893
In classic ship theory dynamic stability is characterized by positive area under stability curve (RM curve). This area is a measure of work required to capsize the boat. Requirements to area under RM curve is fundamental for IMO criteria for commecrial ships and ISO standards for small craft, namely for 'wind and wave' factor. Yes, area is also used in FDS as part of STIX, but this factor is applied to sailboats only.
Only problem with this method - it purely theoretical and does not consider roll damping that can be significant for sharp chine boats and boats with skegs, bilge or fin keels. But this is different story...
Dynamic stability Bertil Sailboats 78 01-27-2011 04:40 AM
dynamic lift calculation csarmvs Boat Design 12 09-24-2009 11:22 PM
CE vs. CLA in a dynamic reality Slowmo Sailboats 3 09-08-2004 06:01 AM
surface effect ship dynamic stability eos Boat Design 2 07-30-2004 06:56 AM
Dynamic Stability aidel_amrd Boat Design 0 04-27-2002 04:48 AM
