| Calculate Sectional Draft? All, For an 11 ft Classic Moth Dinghy, I'm trying to figure out how to calculate the draft required to provide about 100 sq inches of cross sectional area below the waterline midships. Beam is 54". LOA=11' Internet searches turn up how to calculate a quarterback's draft rating, and some hydrostatics calculations for a crazy looking flying foil cruiser but nothing clear enough for me to apply. Can anyone recommend a primer website or good book on the required calculations? I can accept that I may have a learning curve to negotiate here to gain a working knowledge and am willing to do the homework/reading. If you can nudge me in towards the path of knowledge, I'll go there. I also have a Hydro Dynamics engineer sitting four feet away from me at work, but he has been grumpy and busy recently trying to keep road vehicles from blowing up ("ARRGH, deflagration, not explosion..."he says). I know that trim is greatly, greatly subject to where I sit in a dinghy, but want ot capture the draft midships and design a hull with a specific bow and stern trim with me sitting at one specific point in the hull. Intent is to design a hull that trims to allow me to sit forward in light air to reduce wetted area and then slide back in heavier air to promote planing. Regards, Pat Smith Troy, Mi |
| calculate sectional draft Try reading my website for starters.Do not ingore the section on bulbous bows. www.ivorbittle.co.uk Ivor Bittle Last edited by ivor Bittle : 02-23-2008 at 11:23 AM. Reason: No capital letter |
| There is no direct calculation for real hull section shapes. The process is... 1)Select a forebody, midships and afterbody shape along with an estimated rocker profile from an estimated displacement distribution and total weight. 2) Run up a fair set of lines and bonjean curves and a good weight estimate. 3) Using the bonjean curves and the weight estimate, work out the actual displacement distribution curve, waterlines, and trim. 4) Pull the midships area off the bonjeans or displacement distribution curve. 5) Check your lateral planes 6) Figure out the corrections needed to your rocker curves, body shapes, and displacement distribution curve. 7) Start all over at 1).
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 02-23-2008 at 06:51 PM. Reason: typo |
| twin keel 2' draft instead of single 7' draft on 65' | yhxaig | Projects & Proposals | 3 | 11-12-2006 06:25 PM |
| Sectional area curve ? | fcfc | Boat Design | 7 | 01-07-2005 01:52 PM |
| Need to calculate the draft of a boat | tibett | Boat Design | 1 | 11-09-2004 05:07 AM |
| Looking for plans to make small sectional barges | Joseph | Boat Design | 1 | 09-03-2004 02:17 PM |
| Looking for plans to make small sectional barges | Joseph | Boatbuilding | 0 | 08-12-2001 06:47 PM |
