| Buoyancy and Floatation calcs Hey guys, I need some help calculating the buoyancy and flotation for my fishing boat project. I don't know what formulas to use and how to go about doing the calcs. Any suggestions will be highly appreciated!! Cheers, Mr.Design |
| Isn't that fairly fundamental to the design??? Anyway, your boat will need to displace (as in literally move aside) a weight of water equal to the boats weight. So first you need to know how much your boats weighs. Assuming your boat is intended for use in sea water, divide this weight (in kg) by 1.025. The answer is the volume of the hull that will be underwater. So now you need to calculate what the volume of your hull is at a variety of different draughts. If you have not done your design on a computer there is no quick, easy and accurate way of doing this (unless your boat is a very very simple shape). The standard way is too difficult to describe here, but involves using Simpson's Rule on the curve of areas (if you have produced one), but any method you like will do. If you have some maths knowledge you can figure out ways of approximating the volume. Your boat will sit at the draught which gives the volume you calculated earlier. volume = length * beam*draught*block coefficient As a very crude first go, if you estimate the block coefficient as 0.5 then: draught = 2*volume/(length *beam) Hope that helps a little. Is this a college project? |
| USL Section 10 Appendix N., from the nmsc website. Use Google. Viola! |
| If your talking about positive flotation, try this out: (sourced from www.mast.tas.gov.au) Positive Buoyancy Boats fitted or built with positive buoyancy will keep afloat when filled with water. Small boats with no buoyancy fitted or negative buoyancy can fill with water and sink very quickly. If a boat with any sort of buoyancy swamps with water, it should still stay afloat. This can give those on board time to reach life saving equipment, put on their life jackets, if they are not already wearing them, and attempt to bail the water out. A floating boat is an identifiable target for search and rescue efforts. MAST trials show that boats that have underfloor buoyancy were not likely to remain upright but would float either upside down or bow up depending on the weight of the outboard and the buoyancy fitted in the stern of the boat. Flotation material added at the sides, as far aft and as high as possible (up under the gunwales) will under normal conditions, make the boat float level. Even if the boat is swamped, it will stay upright and sit lower in the water, even to where the deck is level with the surface of the sea or surrounding water. If the occupants are tipped out they can get back into the upright boat more easily. Type of Flotation Isothane (green) and Isothex (orange) Polyurethane Forms are available from: - RMAX, Launceston - The Fibreglass Shop - Hobart Amount of Flotation A simple calculation is available for owners of trailer boats to check the required amount of flotation in your boat. This is a guide only. Aluminium, GRP and Steel vessels: 1.2 x (M x K + F) 1000 – D M = Mass of the hull and deck K = Alum 0.62, GRP 0.375, Steel 0.87 Timber vessels F = Mass of machinery and fittings D = Density of buoyancy material (40kg/m3) 1.2 x F 1000 - D Example for an aluminium vessel When: M = 240 kg (hull and deck mass) K = Aluminium 0.62 1.2 x (240 x O.62 + 80) F = 80 kg (machinery) 1000 – 40 D = 40 kg/m3 Required flotation = 0.286 m3 |
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
| Or, of course, look up Simpsons Rule on google
__________________ Trev F – Amateur designer and part-time layabout. |
| Firstly, i apologize if i should not be bumping old posts, but this particular post had so much pertinent information to my question; How do you find out how much a simply rectangular vessel sinks into sea water when it is 142 m long x 18.5 m wide weighing 22000 long tons? PI Design, your first reply gave me much to think about, but i tried implementing some of what you said and seem to be going round in circles... In doing the math it seems that my vessel is going to sink in about 10m?! that can't be right, can it? I've become so frustrated with what first seemed like a really interesting college project, (i'm designing a harbour for my Civils BEng) it just feels as though i'm getting nowhere. Any help would be massively appreciated!! Many thanks! |
| Work out the volume of water weighing 22,000LT, keep in mind the density of sea water higher than fresh water. Vol=mass/density. Also weight must be total loaded weight - ship + payload The volume you have worked out is the displacement volume, which is: the volume of water dispaced by the boat (obviously) and further is the volume of the boat below the water line. To work out the sinkage for a simple flat bottomed rectangular vessel, divide the volume by the water plane area (142x18.5) and you will have the sinkage. I get 8.3m draft, if you want to make it float higher, you will need to make it longer or wider.... and not increase the weight. |
| buoyancy foam for catamaran | northerncat | Powerboats | 7 | 04-19-2007 05:52 AM |
| Buoyancy vs Weight | halfboat | Boat Design | 3 | 03-16-2007 08:55 AM |
| Buoyancy and floatation measurement | enu | Boat Design | 12 | 08-21-2006 08:18 AM |
| Edmonds Calcs | JEM | Wooden Boat Building and Restoration | 0 | 07-22-2004 01:01 PM |
| Positive Buoyancy Floatation foam & Ullage Equation | trouty | Boat Design | 2 | 07-02-2004 09:29 AM |
