Old 08-21-2009, 02:21 PM
Bruce1947 Bruce1947 is offline
Rep: 10 Posts: 2
Bouyancy formula
I am trying to determine how much an all aluminum boat will sink in fresh and salt water. Is there a formula that can be used? Are there any books I could buy or websites I could visit to help me to determine this for various boats?
Old 08-21-2009, 02:37 PM
rasorinc rasorinc is online now
Rep: 678 Posts: 1,129
generally fresh water weighs 62 pounds per cubic foot and salt water about 64 pounds per cubic foot. any thing that weighs less then those numbers will float. Weigh your boat and provide flotation material for 150 percent of the boats weight. Salt water floats slightly more weight than fresh. Aluminum only floats because of displacement.
Old 08-21-2009, 03:56 PM
nukisen's Avatar
nukisen nukisen is offline
Rep: 114 Posts: 380
I do usually count with 1,028 /m3 for salt water and 1 for fresh water.
If possible put the hull into freeship and it will calculate it for u.
The more I learn the more I do understand that I do not understand. :)
Old 08-21-2009, 03:59 PM
nukisen's Avatar
Rep: 114 Posts: 380
And then you can calculate the weight of the ship
Old 08-21-2009, 07:33 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,692
It is just the ratios of FW to SW or if you wish mathematically:
Displacement = water density x volume
Water density or SG
FW = 1.000
SW = 1.025
vol = LxBxTxCb.
L= length
B= Beam
T = Draft
Cb = block coefficient. (if you not sure just use say 0.6 for both calc's, doesn't matter if constant)
Units SI/metric, not imperial.
Old 08-21-2009, 07:39 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Geezzz guys, didn't we decide on the other thread we are going to use metrics
Weigh your boat and provide floation material for 150 percent of the boats weight.
This is very conservative, I would think the ratio should be much bigger, I would think more to 300 or 400 percent at least, but that would also depend on the boat size and purpose.
Regards
Fanie
Water ! Just gimme water !
Old 08-22-2009, 02:12 AM
nukisen's Avatar
Rep: 114 Posts: 380
Me and AdHoc gave a little different dens of saltwater.
Both can be used and will not make a very big different.
The salt water dens. is cause by salinity. High salinity higher density.
AdHoc i Have seen that you always know ur things.
Have a nice day!!
Old 08-22-2009, 04:32 AM
Naval Architect
nukisen
"..AdHoc i Have seen that you always know ur things..."
Well, it is my daily job....I'd be worried of didn't know these "things"
Thanks for the compliment though ..
Old 08-22-2009, 08:35 AM
Rep: 10 Posts: 2
Followup to buoyancy
Water density or SG
FW = 1.000
SW = 1.025
vol = LxBxTxCb.
L= length
B= Beam
T = Draft
Ad Hoc, thanks for the reply. I guess I am a little dense, but I have some more questions.
1. What is the block coefficient? Is it different for different boat materials, or maybe it doesn't matter?
2. If I have a cabin on the deck of the boat with doors, do I include it in the volume calculations?
3. How do you know what the draft is if you haven't a boat to check it?
I assume draft is defined as how much of the boat sits underwater?
4. What is "Units SI/metric?
New question on stern or bow heavy: How can I determine whether an all aluminum boat will sit evenly in the water? Do you know any websites or books that can help me learn about buoyancy and displacement?
Thanks, Bruce
Old 08-22-2009, 11:36 AM
Naval Architect
Bruce1947
Not dense, no. You're just not familiar with the all this "boat" terminology and its definition.
Most of your questions can be answered by simply buying a book on naval architecture, a simple one. Since as i ahve just noted, most of the "words", such as block coefficient etc are all basic definitions with exact definition in relation to a boat. Answering one of these question swill lead to another Q, because it is all new terminology.
Therefore, it is best to get some basic book that explains the basics of naval architecture. Otherwise we could be here a long time!!
Old 08-22-2009, 12:12 PM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
Water density or SG
FW = 1.000
SW = 1.025
vol = LxBxTxCb.
L= length
B= Beam
T = Draft
thats the "formula" you asked for Bruce but i too had to think a sec on FW / SW
if you want it real easy do a metric quick rough one: 1 klogram displaces 1 liter water
Old 08-22-2009, 02:03 PM
Fanie's Avatar
Fanie
Bruce, you don't have to learn a formula for it, it is rather common sense. If you push a 2L coke bottle under the water you are displacing 2L of water.
If you dunk a 1000kg hull on the water then you displace 1000kg or 1 cu meter of water, even if the hull is not 1m x 1m x 1m. It is the weight of the floating item displacing the 1000kg.
The size of the thing you have, when submerged will be the total volume of the water you can displace. Volume is length x width x height, you know that already.
Just keep in mind you want the boat to stick out on top of the water some, so don't calculate the full volume for UNDER the water
Even heavy boats can seem to sit on top of the water, and not sink into it.
Only keeled mono hulls does that and there, I've just started the next forum fight
Regards
Fanie
Old 09-24-2009, 10:32 PM
Scott Carter's Avatar
Scott Carter Scott Carter is offline
Rep: 143 Posts: 130
Bruce,
A very basic but IMPORTANT distinction you need to remember to make (this is in reference to your question #2 above) is that the volume we refer to has nothing to do with the cabin or other appendages of the boat (even a lot of the hull itself). The volume which is to do with displacement is the volume of the submerged section of the hull, referred to as the underbody. The rest of the vessel (cabin, etc) does however affect the overall weight of the boat, and so therefore how far it sinks into the water as a function of its displacement.
If the boat has a waterline evident you can get a pretty close aproximation of the boat's displacement just by envisioning the underbody as a series of triangles, calculating the area of these various size triangles along the length of the hull and multiplying by the length of the hull they represent to determine their volumes, the sum of which equals (approximately) the volume of the underbody of the hull. This volume, multiplied by the density of water (as given in the above responses) will give you the boat's displacement, and thus its weight. Conversely, if you know the weight of the boat, divide this number by the density of the water you'll put her in to, and this will yield the volume of water displaced by her partially sunken hull. It'll then be up to your math to determine at what depth of the hull (draft) this volume is reached.
Old 09-26-2009, 12:50 AM
pamarine pamarine is offline
Marine Electrician
Rep: 70 Posts: 147
Rhinomarine works great for calculating static and dynamic waterlines. But, you would need a 3-d model of the vessel with weight and cg information.
Basically what Ad Hoc and Scott have said is the answer. The displacement of a vessel is fairly easy to compute. It is equal to the vessel weight.
Finding the static waterline (which I am assuming is what you are after here) is determined by the hull shape and size (volume) that causes the displacement of an amount of water equal to the weight of the vessel. Ad Hoc's formula will tell you this.
The next step is probably the most difficult to do without a computer program (not really difficult, just labor intensive) and that is to find what portion of the hull gives you the volume of water calculated above.
To find the actualy WL you will need to know the Center of Gravity of the vessel. As the CG moves fore and aft, the hull will pivot around the lateral axis (bow will rise and fall) and as the CG moves athwartship the hull will pivot longitudinally (list port or starboard). Ideally you want the CG on the hulls centerline and I typically will try to place it in the middle third of the hull's legth but abaft the geometric center (for a planing hull). This will give you a slight bow high attitude at rest. once you know the vessel's attitude you can then figure out where the WL needs to be to give you the desired displacement.
Now I am self taught so excuse the lack of polish in my answer, but I hope it helps
Old 05-11-2010, 12:53 PM
trevormlb trevormlb is offline
Rep: 10 Posts: 3
So if I have a boat with a 500lb weight capacity in fresh water what is the weight capacity in salt?
adding bouyancy ? gramos Multihulls 10 09-27-2008 04:25 AM
Bouyancy of float Float builder Boat Design 2 08-30-2007 07:56 PM
What foam can be use for bouyancy?????? MarioCoccon Sailboats 17 08-26-2006 04:15 AM
bouyancy materials wannabe Materials 1 07-15-2004 12:05 PM
Bouyancy Ted1785 Boat Design 30 08-11-2002 06:55 PM
