Old 07-14-2009, 09:36 PM
CapeCodAngler CapeCodAngler is offline
Rep: 17 Posts: 17
Best way to adjust trim?
I am restoring a 1978 19' Midland Skiff. We installed a 90 HP Four Stroke Honda and the boat sits back more than it should. (boat is rated to handle up to a 115 HP two stoke). I moved the gas tank and console forward, but still need more weight in the bow to level the boat. What is the best way to do this? Lead in the ballast?
Suggestions would be appreciated.
Thank-you
Old 07-14-2009, 11:10 PM
Stumble Stumble is offline
Rep: 550 Posts: 921
I am normally opposed to adding any dead weight to a boat for trim issues since it will decrease fuel efficiency from dragging around all the weight. On an outboard slightly adjusting the trime angle of the engine should solve this problem, but if it wont then I would look at a set of small trim tabs. Probably a set of fixed ones would work, though hydrolic ones offer more control.
Old 07-14-2009, 11:28 PM
DaveJ DaveJ is offline
Rep: 66 Posts: 131
I don't want to point out the obverious, but have you adjusted the motor leg fwd as much as possible, move the pin that stops the leg from going fwd, fwd. If it is then maybe try something like a outboard hydrofoil. try this thread.
Outdrive/Outboard Hydrofoils
Dave.
Old 07-15-2009, 01:20 AM
stimulous check stimulous check is offline
Rep: 10 Posts: 14
At speed the type of prop will also make a difference. A cleaver would help as it won't create the bow lift.
Old 07-15-2009, 02:32 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
At rest? If so reckon it's the 4stroke engine being more heavy than 2stroke 115's..
Old 07-26-2009, 11:00 PM
Yellowjacket Yellowjacket is offline
Rep: 287 Posts: 242
Since you have a lot more weight aft you obviously need more lift aft (assuming that you are talking about planing trim here). An afterplane (full width trim flap) set to be level with the current bottom will do the job nicely, you will gain both speed and efficiency if you are too nose high currently. A flap of up to a foot in length could be added to give you what you are looking for here.
I would suggest that you model your current boat in a Savitski calculator (the one by Dingo Tweetie is find for what you are doingm and it is available right on this forum in the software area here is the link... http://www.boatdesign.net/forums/dow...do=file&id=40). Simply match what you have to the best of your ability in the spreadsheet and that will be a good starting place. Then add additional bottom length and move the cg forward the same amount as you added to the length and that should give you a very good idea as to how much it will do for you.
This is the best thing you can do to solve your problem with the minimum impact on cost, efficiency and performance.
Old 08-01-2009, 05:19 PM
pistnbroke's Avatar
I try
Rep: 372 Posts: 1,230
what we have not establiished from this guy is the actual problem
Is it that its low in the water when stationary ..there is little you can do about that but build a motor well ....whats the transom height ?
Is it a problem on the plane ....and so whats the problem ... motor should tucked right under when you hit the gas and then trim up once on the plane ...keep trim down in rough weather ....
A 90- hp 2 st is 125 kg 50 kg lighter than a 4 stroke but thats only 1 light guy standing at the back hauling in a fish and a 115 2 st V4 is the sameweight as the 90 4 stroke ( yamaha quoted )
More details please ...
adding another foot to the back is an ugly idea that will not help at rest ....two boyancy chambers either side of the motor or side fitted pontoons can give more lift and have been used before and are in fact over the counter items in the USA...
Old 08-01-2009, 09:40 PM
Rep: 17 Posts: 17
Thanks Gentlemen
I took the easy way out and sold the boat. Thanks for your comments.
Need help with interior trim kart 35 Boatbuilding 0 06-16-2006 02:30 AM
Tilt and Trim bigbuck Powerboats 1 05-10-2006 07:12 PM
2 rudder toe in adjust fx152 Boat Design 2 07-27-2005 04:45 AM
just the trim hannahsmom Wooden Boat Building and Restoration 2 06-12-2005 06:50 PM
ASC Concept (no heel auto-adjust sail) Jeff Sailboats 0 06-02-2002 08:06 AM
