Old 01-28-2010, 07:07 PM
fishon91's Avatar
fishon91 fishon91 is offline
Rep: 10 Posts: 43
bateau style calculations
i have no clue how you guys do your calculations to figure out exact stability, and, just to save lots of confusion, please don't teach me over the internet.
but i would like to know what you guys think about this style of boat:
http://www.mudmotortalk.com/mmt_v2/v...=bateau#p66138
i'm thinking about sellin the hull i've got now to help in paying to build a new hull. this would be the first time i built a hull before. it doesn't plane out good because of the weight of the desk i put in front, and is only 3' wide so not very stable
i'd like top build this boat for my 11hp mud motor(homebuilt), i like this style becuase i believe i can make it 4' wide at transom, and when its on plane there won;t be much of the boat in the water, so there's less resistance. i also like the pointed hull. i'm just wondering will it be very stable as it is? will putting podshttp://www.explorebeavertail.com/flotationpods.html on it be a bas idea, i don;t see any reason why it would be.
with the ideas i've got now, this could be a fantastic boat for my small motor, just wanting to know what you all think.
Old 01-28-2010, 07:13 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,359
It looks fine. Stability goes down as center of gravity goes up. Keep weight low and there should be no problem.
Hoyt
Old 01-28-2010, 07:14 PM
fishon91's Avatar
Rep: 10 Posts: 43
what do you mean by go up? higher altitude? or up to bow? sorry that may be dumb question.....
Old 01-28-2010, 07:15 PM
hoytedow's Avatar
Resistor
Higher altitude. Like a corvette can swing through a fast turn more stabile than a semi-truck with a full load.
Hoyt
Easy calculations kjell Software 31 10-31-2010 02:17 AM
simple kayak or jonboat/bateau using coroplast? richg99 Fiberglass and Composite Boat Building 4 09-30-2009 02:14 PM
Construction calculations jamiehides Software 4 05-04-2006 01:17 PM
Calculations? bearwen Boat Design 3 12-03-2005 12:22 AM
Prop calculations GeoffSChapman Boat Design 12 03-01-2005 02:26 PM
