Old 11-28-2009, 12:02 PM
ricardo.halfeld ricardo.halfeld is offline
Rep: 10 Posts: 4
Batch Equilibrium Analisys
Hey all,
I'm designing an Offshore Supply Vessel to carry a variety of fluids. I have about 60 tanks and I'd like analize the equilibrium and stability of every loadcase. What software would you recommend to run this analisys?
I'm currently using HydroMax (a part of the MaxSurf pack) which is very cool but I have to set each loadcase manually. I would really like to have it done automatically...
Old 11-28-2009, 08:17 PM
yuyewuyuconan yuyewuyuconan is offline
Rep: 10 Posts: 35
HI ricardo.halfeld
I think NO software can deal with you problem.
but in HydroMax you can cope and paste all tanks one time,i think it is not a larget work.
Old 11-29-2009, 05:39 AM
Rep: 10 Posts: 4
The real problem with HydroMax (at least in the version I'm currently using) is that the maximum number of loadcases is 25... and I have about 56 tanks in my vessel... So it's a lot of work. Thanks anyway.
Old 12-02-2009, 03:27 AM
ontwerp ontwerp is offline
Naval Architect
Rep: 32 Posts: 27
Macros and Run Files
If you are using NAPA you can make a simple macro to load each tank with what fluid you want and check the resulting draught trim, etc, and check all the relevant intact stability and longitudinal strength criteria with one "button".
I think you can do something similar with PIAS and GHS by making a run file, but I recommend NAPA because it is fast and accurate.
Xfoil in batch mode fastwave Software 1 12-13-2007 02:09 AM
How large of a epoxy batch? MichaelG Boat Design 5 11-07-2007 08:11 PM
How large of a epoxy batch? MichaelG Fiberglass and Composite Boat Building 11 11-06-2007 07:47 PM
