Old 01-20-2011, 11:19 AM
gtflash gtflash is offline
Rep: 10 Posts: 34
adding keel to deep v
What would be the pro and cons of adding a keel to a deep v planning hull capable of 35knots, would it stop it planning, or push its nse down, or just reduce top speed and increase stability at rest??
Old 01-20-2011, 11:56 AM
Rep: 1493 Posts: 7,447
Less speed, more fuel consumption, possible erratic handling, unbalanced trim.
Old 01-20-2011, 02:33 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2042 Posts: 1,719
And no additional stability at rest, less in fact as the additional volume floats the boat higher and reduces waterline beam.......
Now if you are talking about a ballast keel.......that's a different story
Old 01-20-2011, 03:27 PM
tom28571 tom28571 is online now
Rep: 1500 Posts: 1,681
Tad,
Bite your tongue. Why would anyone add ballast to a planing hull? Certainly not to one of yours. Then again, we might like to know why the OP wants to add a keel to a deep V in the first place?
Tom Lathrop
Old 01-20-2011, 03:31 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Originally Posted by tom28571 View Post
Tad,
Biting...ow!....why?.....who knows?
Old 01-20-2011, 03:57 PM
Rep: 10 Posts: 34
Tad,
OP??
Thinking a minimal design, similar to pictured, more than the need for adding a keel, im more interested in the pro and cons.. such as gonzo reply.
Old 01-20-2011, 04:08 PM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 962 Posts: 631
With a keel you may end up with a hull that is heeling over and planing on the keel and one side of the bottom, depending on proportions of (keel area)/(bottom area) and speed. It has been done, this is what happens with some overpowered semi-displacement hulls. So, unless you are prepared for a considerable amount of trial and error: DONīT go that route!
Old 01-20-2011, 08:29 PM
Rep: 3125 Posts: 9,408
That's a skeg not a keel, though it's likely attached where part of a keel would be, if that particular boat actaully had one. As a rule you don't want appendages or other protuberances under the boat if you can avoid it on planning hulls.
Old 01-20-2011, 10:07 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
As PAR stated, that's a skeg rather than a keel - probably added more for prop protection than any sort of stability - which could be improved or reduced as others have said.
It doesn't really look like a 35 knot boat either...
A better way to improve initial stability (whilst at rest) in a deep-v is to have a hole in the transom to allow water to fill a ballast tank whilst at rest. The water can then freely flow out once the boat starts to pick up speed, so you're not carrying around any extra weight or additional wetted surface. This is easier to achieve in outboard powered powered boats, of course...
oh... and OP is short for original poster...
bloody acronyms can drive you mad, I know!
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 01-20-2011, 10:56 PM
Mr Efficiency Mr Efficiency is offline
Rep: 246 Posts: 712
Surely the OP wasn't looking to increase stability ? Certainly no joy in the keel idea there. With the ballast tank idea, no doubt has some merits, but you need it to be full with no slosh factor, and vented well to allow quick draining on take-off.
Old 01-20-2011, 11:13 PM
I don't know what he's trying to achieve as he hasn't told us...
Could be an imrovement in initial stability whlist at rest, could be an improvement in dynamic stability whilst underway... who knows....
The problem with deep-vee's is that in order to be suffuciently submerged so that the chines are immersed - so giving them much better initial stability at rest - they generally need to be quite heavy.
The open transom is one solution to the problem and I've been on a number of boats where it makes a hguge difference. The earliest probably being the Bertram 25 when they came out with OMC Seadrives (basically o/b's). The boats were faster and more economical than their sterndrive counterparts, but suffered badly from having the chines out of the water at rest.
You are correct, however, the "hole" on the transom needs to be as big as possible and vents are required in order for it to fill and empty quickly.
Will
www.imaginocean.net
Old 01-20-2011, 11:24 PM
I gathered that the original poster wanted to know the pro's and cons, which he should have surmised by now. I don't think he's looking to install a "keel" on his Bayliner, but who knows.
Old 01-21-2011, 07:19 AM
Tad,
gtflash,
My first comment was playfully directed at Tad. The second was a question to you, to which you have not replied. Obtuse questions get obtuse answers. Most here would rather not have to guess at what the question really is. There is no reasonable reason to put a keel on a 35kt planing deep V.
Tom Lathrop
Old 01-21-2011, 02:18 PM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
The only significant benefits of a skeg on a planing boat are to fair in the propeller tube, and to change (usually increase) the directional stability of the hull. Effectively, it's like increasing the deadrise angle, and it can be used to improve the handling on a shallow V (i.e. 10 deg DR) hull. Deep Vs (over 18 degrees typically) have little need of it, unless there really is a problem with directional stability.
The effect on static stability and roll damping are negligible. Cons? It adds drag. It may actually de-stabilise the boat in certain down-seas conditions if you make it excessively large.
Cheers,
Tim B.
Old 01-21-2011, 02:56 PM
Deep V's can be impressively stable on sand bars . . .
OK.........take a deep breath (adding sail to houseboat?) GOTTABSOMEWHERE Boat Design 23 07-13-2009 10:44 AM
Adding Ballast In A Keel saildog Sailboats 5 11-22-2007 09:22 PM
Elan 36 short vs deep keel knuterikt Sailboats 8 08-13-2006 11:41 AM
Adding A Keel AAAAPPPP Powerboats 1 05-26-2004 12:47 AM
adding keel Open Discussion: All Things Boats & Boating 1 01-24-2003 06:41 PM
