how to draw bulbous bow using rhino??
Discussion in 'Software' started by tjrrong, Aug 2, 2004.
  1. tjrrong
    tjrrong New Member
    any members have experinece drawing bulbous bow using rhino.....
    Pls provide to me ..
    thanks
  2. CGN
    Likes: 9, Points: 18, Legacy Rep: 138
    CGN Senior Member
    Hi, what i do is just "push and pull" using the vertexes to shape the bulb, i will say that usually your bulb will be faired into the hull, as a part of the hull, so i use one surface with as many controls points on it so i can shape it, in the way i want.
    this is if i'm creating the hull form scratch.
  3. Polarity
    Likes: 7, Points: 0, Legacy Rep: 148
    Polarity Senior Member
    Sorry did not see you had posted here, I replied to your PM
    But for anyone else interested here is a copy
    First you have to realise I can only tell you how to draw it simply in rhino.. I'm not a designer!
    If you have not already check out my tutorial on drawing a quick boat hull.
    http://boatdesign.net/forums/showthread.php?t=1401 should take you right there...
    Then in profile
    Draw the bow line and the profile of the bulb using control point curve - make a smooth transition
    put a point at the end of the bulb
    Plan view
    draw the half plan shape of the bulb - start at the point end just beyond where you think it will meet the hull surface
    Loft.
    mirror
    see turorial instructions for removing the "kink" where the shapes join.
    Offer up to the 3d hull surface and either trim or boolean union
    Will post a pic or two in my gallery for you. http://www.boatdesign.net/gallery/showgallery.php?cat=500&ppuser=173
    Hope that helps!
    Paul
  4. cestes
    Likes: 1, Points: 0, Legacy Rep: 60
    cestes Junior Member
    The short answer is that you create the hull, then create the bulb, trim each back some distance and blend between the two.
    This will create a surface, which has curvature continuity (g2) at each edge.
    The long answer requires many paragraphs and illustrations, but is possible.
    We will be doing a Rhino Marine Modeling class online at http://www.emarinetraining.com starting in September. In that class, it will be possible to delve deeply into this question.
    The class will take six weeks and will involve learning creating and fairing curves and surfaces. In week 3 we will create a hard-chine model. Then in Week 4, a molded hull sailboat.
    Finally, each student will spend the last two weeks doing a self-directed project with supervision from the instructor.
    Check it out at emarinetraining.com
    Regards,
    Cliff W Estes
    BaseLine Technology
    Rhino reseller and user.
  5. mdburges
    mdburges New Member
    Paul,
    I'm and undergrad student at UBC and I'm doing a project on the design of a bulbous bow for a 'thin ship'. Anyways, I've followed your instruction, but I'm having trouble at the loft stage. Whenever I loft, it seems to give me an 'inside out' bulb. Do you have any suggestions?
    Thanks,
    Mike
  6. mdburges
    mdburges New Member
    I think I figured it out, but thanks anyways.
    Mike
