Engine Compartment Cover
Discussion in 'Fiberglass and Composite Boat Building' started by Scotts, Jul 28, 2006.
  1. Scotts
    Scotts Junior Member
    New to boating. Just pickup a 1985 Horizon 195 Cuddy and i have some parts i need but am having trouble finding them. The main one i need is the engine compartment since the one on my boat is deteriorated. Is there a site that sells them or Should i look for someone to build it or is it something i can build myself? Any help would be great
  2. marshmat
    marshmat Senior Member
    Are you talking about the hatch over the motor? On most older small runabouts this is just a plywood box, with vinyl on the outside and engine-room insulation on the inside. Some fancy older boats (and most newer ones) have fibreglass engine covers. The wood version, you can probably build yourself, using the old one as a reference.
  3. Scotts
    Appreciate the reply
    Do i need to use resin and cloth to make it waterproof and then carpet? What size plywood should i use? Also the old one is so decrepid that i couldnt even use it as a guide is there somewhere i can get the dimensions?
  4. Deeman
    Deeman Junior Member
  1. Flyingpumpkin
  2. pistonfields
  3. cadmus
  4. Scuff
  5. WalleyeSniper
  6. E350
  7. chowdan
  8. SecondChance248
  9. Aktroller
  10. headsmess
