Bedding Stringers
Discussion in 'Fiberglass and Composite Boat Building' started by rbt, Mar 1, 2006.
  1. rbt
    rbt Junior Member
    In replacing the stringers in my 17ft Aquasport I am considering bedding them in 5200 rather than epoxy. The stringers are modified 2x10's treated with CPES and are going back into the original fiberglass sheaths. The sides and top of the stringers will be coated with modified epoxy and the top fiberglass cap installed. I read quite a bit about epoxy hard spots so I thought 5200 may be a better choice for the contact between hull and stringer.
  2. jimslade
    Likes: 3, Points: 0, Legacy Rep: 27
    jimslade Senior Member
    It would be a waste of money. Set the wood just above the bottom. If you want to make sure that you are not contacting the bottom you could use a strip of foam to set your stringers in.
  3. rbt
    rbt Junior Member
    Jim,
    thanks for the reply, but I do want to secure the stringers to the hull bottom. I thought 5200 might be a little more flexible than epoxy.
    Thank you
  4. JR-Shine
    Likes: 4, Points: 18, Legacy Rep: 54
    JR-Shine SHINE
    I’m curious why you would not want your stringers secured to the hull
  5. rbt
    rbt Junior Member
    You must have misread this, I do want to secure the stringers to the hull bottom, just thought 5200 would be a little more flexible than epoxy, and possibly a less costly solution. Although at $15.00 a cartridge, it is closing the gap on epoxy. Thanks for the interest.
  6. JR-Shine
    JR-Shine SHINE
    I am willing to bet it would be cheaper (and a lot stronger) to glass them down with epoxy and biax ;)
  7. jimslade
    You dont want the stringers to touch the bottom of the boat because you will setup a stress point on the bottom that will cause all sorts of structural issues.
  8. JR-Shine
    JR-Shine SHINE
    The ideal way to do it is to rest have the stringers rest on a foam trapezoid - the glass the whole thing down
    In this picture, you will see two stringers (already glassed on top of foam trapezoids), and a bulkhead which is sitting on the foam trapezoids waiting for glass
  9. rbt
    rbt Junior Member
    Interesting, they float on the foam, but are trapped in the fiberglass shell. Originally mine were set on a type of hardened filler, and I assumed they had released because of moisture intrusion. Stringers are never hard fastened to the hull bottom? Thank you both for the replies.
  10. JR-Shine
    JR-Shine SHINE
    The stringers were probably bedded down in Plexus or some adhesive – that’s the way production boat building works. The reason they do it this way is cost – its quick and saves labor, not because it’s the best way.
    What you see above (while not pretty work) is a better way to install stringers. There are no hard spots, the load coming from the hull is spread out evenly through the fiberglass skin (multiple layers of biaxial cloth) to the stringers.
    There is nothing secret or ground breaking here.
  11. rbt
    rbt Junior Member
    Good information, thank you.
  12. basstardo
    basstardo Junior Member
    Good information! :)
  13. IHTFP
    IHTFP Junior Member
    JR Shine,
    Where can you get the foam trapeziods? Are they made exclusively for boatbuilding. Also, when installing stringers in a deep V bottom, does the technique change any?
    Thanks
  14. SamSam
    SamSam Senior Member
    You just cut them yourself out of foam that won't be dissolved or affected by the resin system you are using. They are not structural but only serve as a form for the fiberglass tabbing and help smooth the 90 degree transition and distribute the stresses between the bulkhead and the hull. Sam
  15. eyes
    eyes Junior Member
    Got a question regarding to bedding the stringers.
    I know Jimsdale wrote not to place the stringers touching the bottom, understood. But what do you use for filling between the stringers and hull befor you glass them?
    1. holorinhal
    2. Shawn Barlow
    3. Jason Grubb
    4. BernieJ
    5. Bigtalljv
    6. Bigtalljv
    7. 67-LS1
    8. Bigtalljv
    9. cadmus
    10. Martin Upton
