Zoro
Size doesn't count!
- Joined
- Jan 12, 2006
- Messages
- 51
- Reaction score
- Location
- Melbourne Australia
I would like to have a go at designing and building a 25' ish trimaran based on a NACRA 5.8. The idea would be to utilised as much as possible from the NACRA "donor boat" (hulls, rig, sails running rigging) to reduce the cost of building the trimaran as much as possible. Highly affordable is the number one objective!
This type of thing has been done before using the Tornado Cat as a donor boat. The boat was designed by a guy named Kelsall and was called a Typhoon.
Typhoon study plans and photos...
NACRA 5.8
The L7 a similar kind of boat...
The Typhoon was a production boat and unfortunately there are no plans available.
I have downloaded Freeship and I am getting used to using it but other than that I have no design skills at all. I have in the past rebuilt boats and converted a swing keel yacht into a fixed keel yacht so have some idea... but thats about the extent of it.
My thoughts are to try and create a fairly fine central hull that flares above the waterline, (the NACRA 5.8 rig will be on the light side if the weight is not kept down) with a cuddly cabin (2 berths/seats is about all) and a reasonable cockpit. I thought the easiest thing to do would be to retain the NACRA's rig position relative to a centre board/ dagger board in the main hull and the floats (NACRA hulls) and balance the main hull evenly (fore and aft) against the floats. Construction would probably be tortured ply or strip plank cedar..
If anyone feels inclined to get involved I can use all the help/advice I can get !
What do you think... am I mad or what?
Has it already been done? (ie Should I just buy the plans!)
NACRA 5.8
