No Limit reached limit
Discussion in 'Boat Design' started by Dutch Peter, Sep 7, 2004.
  1. Dutch Peter
    Likes: 8, Points: 28, Legacy Rep: 66
    Dutch Peter Senior Member
    Anybody know what happened here?!
    (see pics)
  2. senior31refit
    senior31refit Junior Member
    Might be completely wrong here, but was it launched by an imbecile and due to high forces on launch it broke its back?
  3. Dutch Peter
    No! This was the third trip since launch, half laiden with wet sand, in the lock!
  4. senior31refit
    So you know what happened to it then!?!?! Why was it shipping sand?
  5. Dutch Peter
    Common practice in Holland, we need that for building roads, houses, more Holland etc.
    Yes, I know what was wrong. Just letting you pick your brain. Any other bright ideas?
  6. senior31refit
    Well wet sand is a whole lot heaveir than dry sand, maybe it got wet.....
  7. Dutch Peter
    No, these vessels are normally designed to carry wet sand in their holds up to the top of the coaming!! The coaming becoming part of the freeboard and the vessels sailing with their deck at water level! And this one was only partly filled.
  8. SailDesign
    Likes: 197, Points: 73, Legacy Rep: 650
    That's what happens when you unload the ends without lightening the mid-holds. :)
  9. jehardiman
    Likes: 1,510, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Without an inboard and midships structural plan one can only conjecture. Last photo seems to show that she buckled the hull panel between deep frames rather than fail the hull girder. This would be indictive of a loss of section shape (due to damage or deflection) or insufficient panel end ridigity in Euler buckling. If new and sound I would go take a very close look at the hull bending analysis and any FEA done for loading conditions. This may be a simple element mistake.
  10. sorenfdk
    Likes: 27, Points: 28, Legacy Rep: 394
    sorenfdk Yacht Designer
    An elephant escaped from the zoo and jumped on board to hitch a ride?
  11. dougfrolich
    Likes: 22, Points: 28, Legacy Rep: 225
    dougfrolich Senior Member
    Looks like the middle was heavier than the ends!!--Like ore boats of the great lakes, way toooooo long for thier width and depth, for my taste
  12. Dutch Peter
    The solution:
    Original design was 86 mtrs, the one in the pictures is 110 mtrs.
    The skipper wanted some more roomfor him and his mate.
    The analysis afterwards revealed that the boat had only 20% of the longitudinal stiffening it needed.
    Somewhere a limit was reached!
  13. MikeJohns
    Likes: 210, Points: 63, Legacy Rep: 2054
    MikeJohns Senior Member
    So it was the elephant that broke the last straw.
    Don't you guys over there in Dutch land have a survey rerquirement for commercial shipping? Thought you were in the EU now?
  14. Dutch Peter
    As I understand it, this vessel's structure has been appraised by Netherlands Shipping Inspectorate, but they waived any responsibility. It's not required to be a classed vessel!
  15. mmd
    Likes: 18, Points: 0, Legacy Rep: 309
    mmd Senior Member
    That looks expensive. Good thing its in the land of the heavy-lift ship.
