Go Back   Boat Design Forums > Employment and Education > Services & Employment
Old 04-08-2002, 01:37 AM
need help with finding hull designer
We are starting a new boat manufacturing company and need some help with the computer designs so that we can have a plug milled. We are in the early stages and could use any helpful hints that people might have. It is looking like a very expensiive process to design a hull and have a plug milled. Any suggestions to help minimize costs would be greatly appreciated. Also any good contacts in marine design or mold building would also be greatly appreciated. We are located in the Seattle area but could travel elsewhere to have the work done if necessary. thanks
Old 04-08-2002, 03:28 AM
David Dobbs David Dobbs is offline
Rep: 10 Posts: 9
What is the size of the boat you are planning? Sail or Power?
Traditional? Modern Sportboat? Sportfishing? Performance? Cruising?
Are you doing the 3D modeling and engineering yourself, or will you have the final engineering done based on your concepts? I gather you are going to produce the plug using CNC milling - do you also want to have the mold built or might you construct the mold yourself?
Without a few more details, all I can say at this point is do every step to the highest quality possible and the end result will justify all the work you put in along the way.
Old 04-08-2002, 03:47 AM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
Here is the section of our directory which deals with CNC Plug and Mold Making:
http://boatdesign.net/Directory/Boat...D_CAM_and_CNC/
If anyone has additional links that we should add to this section, I would love to have them, so please list any addition companies, large or small, in this thread.
Old 04-08-2002, 03:59 AM
Jeff's Avatar
Moderator
While I'm at it, here is our list of Yacht Designers and Naval Architects:
http://boatdesign.net/Directory/Designers/
(small, medium, and large)
Others reading this will probably jump in with some specific leads, though it would help if you could tell us more about your project and what specific roles or tasks you would like to outsource to a consultant or service provider.
Old 04-12-2002, 01:08 AM
sorry I wasn't a little more specific. We want to start a new boat manufacturing company. We would like to begin with about a 19.5 ft runabout and eventually move into other sizes. Anyone that is reasonably priced, creates good looking designs and works often with small companies would be what we are looking for. Yes we have contacted some CNC milling companies. We are based in Washington State and have talked to Janicki about doing the milling. But we need to find someone who can come up withan engineered design from our preliminary drawings. thanks
Old 04-17-2002, 10:55 AM
Triton Design Triton Design is offline
Rep: 10 Posts: 3
CAD Modeling
I would be interested in speaking with you regarding your new company. I specialize in these types of projects and I am located in Seattle. I run Unigraphics Software version 16-18, and have countless hours of Marine fiberglass tooling experience.
Greg McLogan
Triton Design & Development
425-418-2207
Old 04-29-2002, 09:09 PM
yachtdesigner yachtdesigner is offline
Rep: 10 Posts: 20
Designer wanted for small prod. boat
Your project sounds very interesting. Please refer to a posting on this forum for YACHT DESIGN SERVICES (towards the end). Here I describe the services that can be provided to you at a reasonable cost. Actively working within the (power) yacht design/building industry for the past fifteen years, I would be sincerely interested in working with you on an exciting new project. Please contact me at the following if you would like to discuss the initiation of a preliminary design:
Earl G. Alfaro
E-mail: slaega@peoplepc.com
Old 08-28-2002, 12:08 PM
Rep: 1397 Posts: 7,216
Have you inquired about building a well faired wooden plug? I have been building and lofting by hand for many years. One of the advantages of lofting full size is that you can see the appearance of the boat and change it cheaply with an eraser. I can work with your preliminary drawings. As a boatbuilder of sportfishing boats in North Carolina I often worked out of a sketch in a napkin.
Old 08-29-2002, 12:00 PM
yacht design
please, reply with your e-mail address and detailed information on the boat, you wish to construct and I'll try to help you with outline design.
Andrew. pitcha@mail.ru
Old 01-11-2003, 01:48 PM
Kazulin Kazulin is offline
Rep: 155 Posts: 34
We can help you with the design of a 19.5 foot runabout as we have much experience
in runabouts of this size (and larger).
contact us at: kazulin@axion.net
We are located in Vancouver Canada and often go to Seattle which can facilitate all work.
Old 01-17-2003, 07:08 AM
pedja pedja is offline
Rep: 10 Posts: 6
Intresting
I am intresting please send email livingstudio@beotel.yu
Regards Pedja
Old 12-21-2003, 12:58 PM
Ami
How is your project doing?
Do you have a winning design beyond the desired capabilities to produce a new Watercraft?
As you are near Victoria, you can contact me regarding mutually beneficial opportunity open for us, employing real special advanced technology Ami 250 474 3200 ami@superiorhulls.com
Old 12-29-2003, 05:06 AM
EmilSB EmilSB is offline
Rep: 10 Posts: 85
Hi,
If You are looking for something like this, please contact me.
SultanEmanuel@hotmail.com
Old 12-29-2003, 09:31 AM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Now, Emil - I have had a copy of that beast on my puter as a 3D-Studio model since at least 1999. Did you originally draw that?
Steve
Old 12-30-2003, 03:41 AM
Rep: 10 Posts: 85
Now, SailDesign- Why you asking me, for conversation or you are realy interested about this model?
Emil
Westlawn School JCFARER Education 59 08-26-2006 07:34 PM
New Member Stu waring Education 49 04-29-2005 10:22 AM
Crossroads of training and license for Naval Arch. AJacks Education 29 10-18-2004 08:55 AM
