Go Back   Boat Design Forums > Employment and Education > Services & Employment
Old 06-24-2006, 08:50 AM
tonyafc tonyafc is offline
www.magnesiacore.com
Rep: 10 Posts: 18
Magnesiacore looking to connect with boat/ship builders
Hi,
I have a new material that I believe may be well suited for boat and ship building in place of plywoods. Looking for discussion and input on the possibility in Marine Construction applications.
Our website is www.magnesiacore.com.
My email is tony@magnesiacore.com
Old 11-11-2006, 07:56 AM
Rep: 10 Posts: 18
An important feature of magnesiacore material is that when properly sealed against becoming waterlogged it will float in water.
Old 11-22-2006, 06:45 AM
ars-technica's Avatar
ars-technica ars-technica is offline
Naval Architect
Rep: 16 Posts: 192
mechanical test
Do you have mechanical test?
to evaluate this core i need a sheet with
density available
and for each density
compressive strenght
compressive modulus
tensile strenght
tensile modulus
shear strenght
shear modulus
Old 11-22-2006, 10:49 AM
Rep: 10 Posts: 18
I sent you an email using the forum profile. Please email me back and we can discuss this directly. Thanks.
Old 12-02-2006, 04:34 PM
lacasmarine lacasmarine is offline
Rep: 10 Posts: 32
Has anyone used this core. if so let me know how it works out.
Old 12-02-2006, 05:06 PM
Rep: 10 Posts: 18
I can get some samples out to try and you can let me know how it works out.
Old 12-02-2006, 09:11 PM
Rep: 10 Posts: 32
e-mail me for address
thank you
Old 12-03-2006, 09:15 AM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
I'm confused here. At 980 kg/cu.m, it is only just lighter than water, yet is being touted as a better core than plywood, which is far lighter. Currently in the sailing boat world we use cores that run 80 to 200 kg/cu.m, with the heavier one being what we stick under large winches. Where would you want something almost as heavy as FRP but with less strength?
Steve
How do you connect SS rigging to an aluminum hull? BillyDoc Metal Boat Building 12 10-28-2005 02:46 PM
Chinese Steel Tall Ship Builders? Adam Baker Metal Boat Building 4 07-03-2004 11:15 AM
Great Gallion Tall Ship Builders? USA Adam Baker Boat Design 0 06-27-2004 06:52 PM
Steel Tall Ship Builders in China Adam Baker Boat Design 0 06-27-2004 06:49 PM
Exp. Ship builders Needed in LA Archive Services & Employment 0 06-12-2001 05:05 AM
