Go Back   Boat Design Forums > Employment and Education > Services & Employment
Old 08-23-2001, 02:42 PM
Erik Erik is offline
Rep: 10 Posts: 2
I wonder anyone can help me but I am looking for a reliable boatbuilder anywhere in Canada (but I would prefer in the eastern part ) able to built a 10,5 to 12 meter sailboat in aluminium. I have been searching for a while on the Net without real success.
Thank you,
Old 08-28-2001, 08:10 AM
Contact John Meisner at ABCO Ltd., Lunenburg, NS 902-634-8821
website www.abco.ca
Old 09-04-2001, 09:45 AM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
Try also http://www.kanteryachts.com/
I'm sure there are others as well. Check with yacht designers Steve Killing (associated with Proteus Engineering), Bruce Kirby, or Rob Ball of Edson Steering.
Old 09-04-2001, 02:56 PM
East Isle Marine in Georgetown PEI is a shipyard that normally does big stuff (government, commercial, etc.) but is a specialist in aluminum construction and have on senior staff Mr. James McConnell, who built ally yachts in Ontario as McConnell Yachts, then built the America's Cup boat True North in a partnership with Bob Crockett at Crockett-McConnel Inc. in Nova Scotia. With him running the show, I'm certain EIM has the capabilities to undertake your project.
Old 09-04-2001, 04:05 PM
Looks like there are some good leads here, Erik. Allow me to also note that there are some top notch hydro labs in Canada, most notably IMD. People there might be able to give you additional guidance. See http://wwwvl.naoe.ish.dtu.dk/Universities.htm for links.
You might also ask Kevin Milne at http://www.marsmetal.com/
I'd love to hear more as your project develops!
Stephen
Old 03-16-2002, 08:57 AM
Sail Tech Yachts
I saw a segment on TV, where they use one long, flat, developed sheet of aluminium on each side of the hull. They then pulled the sheets into shape over a wooden set of hull sections and welded the sheets together. Using this method, they needed minimum fairing and welding to create a round bilge hull and said they could build a 45ft hull, deck and bulkheads in 3days and at 40% less than a normal aluminium built boat (Don't quote me on these exact figures.).
I think they were in Vancover.
Old 03-16-2002, 12:05 PM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
Re: Sail Tech Yachts
Here is a thread on the method I believe you are referring to:
http://boatdesign.net/forums/showthr...p?threadid=248
Before that thread, I had heard of the method once before but never seriously considered it... Neat that it was featured on TV.
Old 03-18-2002, 06:18 PM
Chris Aslin Chris Aslin is offline
Aluminum Boatbuilding
I build custom boats in aluminum to a very high standard. My latest project was a 40 ' displacement powerboat. I have produced many excellent vessels both power and sail. Pictures are available. The boats I build are very fair and require a minimum of fairing material to achieve a high standard of finish. This can be a big problem with many builders, I have developed a system of manufacture that requires patience and knowledge but results in a superior product. Please e-mail to discuss your requirements.
Old 05-04-2002, 01:24 PM
glugglugglug glugglugglug is offline
Rep: 10 Posts: 3
boat builders
Hi there I'm a aluminum boat designer here on the west coast. There are quite a few aluminum boat builders out here, most are stuck in the grove there in ie. power boats. There is a small company who seem to be willing to do sail or any thing else. I have done some drawing for them they are ironwoodboats.com they are located in the Lower main land BC. I'm not sure you want to go this far a feald to get you boat done but who knows.
Perry
Old 09-26-2004, 10:37 PM
Martijn Martijn is offline
Rep: 10 Posts: 2
Aluminum sailboat questions
Hello Erik
I am having the same problem in finding a reliable boatbuilder (Aluminum). I am also looking to have a 10 to 13 meter Aluminum sailboat built. Would you be able to guide me to the right people? Any help is greatly appreciated. Did you end up building one yourself?
If you can give me a call at 416 822 2621 or email me at martijn@showcasedepot.com.
Regards,
Martijn van der Schoot
Thank you,
Old 10-07-2004, 12:54 AM
Brock de Lappe
Lifelong dreamer
Check out Kanter Yachts in St. Thomas.
Beautiful, solid, well designed aluminum boats.
Old 10-13-2004, 07:42 PM
Previous Member
Rep: 0 Posts: 0
I can help
see my alloy boats in gallery under lazeyjack
email me at hearnyacht@iprimus.com.au
I,ve had my own company building yachts in this medium since 85
regards Stu
Old 10-13-2004, 07:46 PM
Previous Member
Rep: 0 Posts: 0
alloy boats yachts
developed shapes maybe
you pull any shape into a alloy sheet even slightly compound without forming by wheels or rolls and when you hit it with the welder it.ll collapse in the immediate weld area because of the released tension
there are no shortcuts EVER in boatbuilding Yes there are quicker methods which one learns in years of hands on
Writing a book on the practical side of hands on Alloy boatbuilding at the moment
Old 01-01-2005, 03:30 PM
Previous Member
Rep: 0 Posts: 0
short cuts, forget them
and it will look like a pig for sure, it costs just as much to finish a pig as to finish a well designed yacht with beautiful flowing lines
It takes me 160 man hours more to plate a boat with 40 stretched and wheeled [plates than it would take me to build a double chine yacht
see my alloy work in the photo gallery
Old 01-30-2005, 10:09 AM
CCCM CCCM is offline
Rep: 10 Posts: 3
Erik,
If you already need help finding a fine aluminium boatbuilder for your sailboat, I can help you. I know a great one person near Québec city. He is increadible!!
Submersible Sailboat? uber33t Boat Design 74 01-25-2012 09:13 PM
CAE Structural support to sailboat design Giovi Boat Design 1 11-03-2007 05:01 AM
Sailboat as a powered cruiser? Bill Fish 6 Motorsailers 28 05-30-2007 06:46 PM
Please recommend sailboat plans jmwalker Wooden Boat Building and Restoration 9 08-16-2005 04:38 PM
Autopilot System for Sailboat taobsu Boat Design 0 08-09-2005 01:41 PM
