| Engineer/boat designer looking for a job Hello, I'm an engineer/boat designer and i am looking for a job in boatbuilding industry. I have finished National Shipbuilding University of Ukraine and have 3 years of working experience at the yard. Current skills: - 3d modeling in Rhino - hydrostatic, weight and stability calculations - strength and stiffness calculations - hullform design - scantlings design - composite laminate analysis - operating 3-axis CNC milling machine - photoreal render in 3Ds max and Vray also - Hand lay, laminating work and production of molds - precise mixing and use of resins, fibres and plastic materials - use of hand tools A little bit of my works: ![]() ![]() ![]() ![]() ![]() |
| Hi, Just sent you a private message regarding potential work here in Ukraine. Chris |
| still looking for a job ![]() |
| Can you help me with this project? |
| Hi! I can make 3d model of the hull on your picture (of course i will need some more dimensions and pictures) and make calculations in RhinoMarine for planning mode. Than you can 'play' with position and angle of the prop to reach desired trim and speed |
| http://www.correctcraftfan.com/refer...ex.asp?page=06 This is appr. the dimensions of the boat, it might be a bit wider, maximum 2,40m and a bit longer, but maximum 18 feet! Center engine, and a hull with "pocket drive". I have a designer in DK to help me with the details and design, but not with the performance, and the hull below waterline! Perhaps you could email me directly, so we can discuss economy! henrik@kjeldskov.dk Best regards. IC |
| Consulting work needed on design Send me an email if you would be interested in consulting on a design for a 52ft catamaran. Its in rhino and I need a NA to run it through hydro testingnand stability and figure out float lines based on layup schedule. Thanks Luke |
| Luke @ select_sailing@yahoo.com |
| Looking for a job Dear Sushkin, we are a yard in the northern part of Germany, specialized in building custom build tenderboats. We are looking for a young, dedicated boat designer to complete our team. Assistance is needed with 3 D Construction and design for our individuel tenders in close cooperation with our in house production boatbuilding team. We are looking to hearing from you. Kind regards, yachtwerft meyer gmbh ppa. Michaela Meyer |
| Hello, Ismotorsport and Michaela Meyer. I've answered you via email. |
| Please send me your CV: matthew@cmcyachts.com |
| CADMATIC Piping Engineer/Designer job (the Netherlands) | TRS | Services & Employment | 0 | 04-23-2010 03:51 AM |
| I need a job! Yacht stylist and designer - exterior & interior - junior designer | McCormickDesign | Services & Employment | 5 | 03-19-2010 12:51 AM |
| Young Engineer looking for job! | hakangim | Services & Employment | 0 | 04-12-2009 03:11 AM |
| Aspiring boat designer/engineer | freesail | Open Discussion: All Things Boats & Boating | 95 | 02-12-2009 12:21 AM |
| Need boat designer job soon | epicadventures | Services & Employment | 0 | 05-07-2007 08:04 AM |
