| Custom Carolina Sportfish I've been building sportfish in North Carolina for about 10 years now. Wood epoxy plank on frame. I'm looking to start another project. I may be willing to travel and help / teach you how to build a hull. I've worked for some of the best builders in NC including Jim Luxton (founder of Jerrit Bay) I have plans from 24' to 46' feet. I have completed a 24' hull for a charter boat fisherman in Key West, it should be ready to hit the water soon. I've also built a 28' hull for Carolinian Boatworks. The trim carpanters and finish guys are working on it now. Before that I framed 6 boats for Gillikin Custom boats on Harkers Is. NC Bryan Robinson 910-367-1882 |
| Do you sell plans for your boats? I am interested in a 26' Carolina express/ CC with cuddy. |
| I may be able to help. Give me a call at 910-367-1882. Sorry it took so long to reply I havn't checked this site untill today. |
| Hi there, I might be also.. do you have any pics? Cheers kit |
| For Squid Kid Squid Kid, I have plans and and a jig for sale - in 2 weeks time I can have it cut and at your doorstep. The jig can be shipped anywhere in the country. You may call me to discuss if you'd like, and I can show you what the boat looks like, drawings, jig, etc. through a webmeeting if you are interested. Most of my work involves sportfishing boats/yachts. I did the design for the B&D 28 and 34 models, and at one time ran the engineering dept. for Buddy Davis. Darron Shorebreak, LLC 757-422-8779 |
| Kitto, In addition to my last message, I can have the jig shipped anywhere in the world. I have put several jigs on containerships to go overseas, so it can be arranged fairly easily and at reasonable cost. Darron Shorebreak, LLC |
| Shorebreak, When building on a jig how do you get the plywood to form the the jig? How do you determine the angle at which the plywood needs to be cut? Thanks, Squid kid |
| Plywood Squid Kid The jig is set up to provide spacing close enough to bridge the plywood without unwanted deformation between frames. Many jigs will be setup to facilitate longitudinal batons on the hullsides that further limit deformation and act as stiffeners on the interior (to remain after the jig is removed). The plywood seams should be run at 45° between sheer and chine to bridge these frames, and each layer of plywood should be at opposing angles. Using at least 2 layers is recommended. I have found that sometimes large sheets may be used aft but moving forward requires narrow strips to help conform to the shape. Obviously, what is required will be driven by how the jig is designed. Hope that helps Darron Shorebreak, LLC |
| If anyone is interested I have a few true Custom Carolina Jigs forsale all Jigs are CNC cut. Jigs can be picked up in person or Shipped. please contact me cbboatworks@aol.com |
| Hybrid Sportfish | Corpus Skipper | Powerboats | 23 | 06-14-2008 04:29 PM |
| Carolina custom sportfish plans/lines | Breakwater | Powerboats | 26 | 01-16-2008 04:45 PM |
| Custom Carolina Boatbuilder | mulletbucket | Services & Employment | 1 | 01-23-2007 10:22 AM |
| want to build a Carolina Custom? I can help. | mulletbucket | Wooden Boat Building and Restoration | 0 | 11-01-2006 09:58 AM |
| Carolina Sportfish | eurotk1 | Wooden Boat Building and Restoration | 1 | 10-07-2004 11:06 PM |
