Old 10-31-2011, 06:10 PM
Rep: 1729 Posts: 2,463
I much prefer a fitout that can be removed easily in sections to inspect and check the hull interior every 10 years. Then your steel boat will last indefinitely.
But in a fully seamless fitout ( should never do that on a steel boat IMO) well applied foam does fully stop condensation but all the metal should be buried, there are a lot of poor foam jobs too.
On alloy builds not painting the inside means you can afford a better type of insulation.
On one build the client used closed cell fire retardant mats made for the house moving industry, about 17 mm thick similar to the outdoor sleeping mats. I think they line the trucks with them.
Mike Johns.
Old 10-31-2011, 06:59 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1933 Posts: 3,025
Originally Posted by Eric Sponberg View Post
Foaming steel and aluminum hulls from the waterline to the sheer is quite common here in the US.
We used to deal with a yard in the US who were building our designs (at my previous company) under licence. The yard always wanted to spray foam the hulls. As you say Eric, this is common in the US. But it is not common in the EU, in fact you wont find many advocates at all. Especially Class/Flag. If i recall I think one company got rather annoyed at us not agreeing to spray foam (citing Class as an example) and spent some time/money getting it through for Class approvals. Can't recall if they succeeded. We still don't recommend this method, despite what may be common elsewhere.
I also vaguely recall as you point out Mike:
Originally Posted by MikeJohns View Post
It also apparently gasses off considerably for a long time.
This was another reason why, apart from those already mentioned, why we do not recommend spray foam.
Old 11-02-2011, 07:29 PM
watchkeeper watchkeeper is offline
Rep: 41 Posts: 145
Originally Posted by pdwiley View Post
I had a look at MIGRANT (2nd Gazelle built by Tom Colvin). It lasted 30+ years in the hands of the original owner without foamed insulation. Rusted through in less than 5 after the 2nd or 3rd owner sprayed insulation and caused a water trap. When I saw the boat there was an external plate doubler over the rusted area.
I'm planning on the sheet insulation approach myself, over epoxy coated steel. Seen enough problems with the foam in place approach to not want to try it myself.
PDW
I've decided on the same approach. While I have seen for myself the benefits of a thick coat of foam, via an aluminium 42ft sloop that spent a night layed hard over resting on a reef.
The foam prevented mayor ruptures from slamming by wave action, instead was reduced to buckled plates with only one minor tear.
But getting the foam out and off the frames etc was an epic task, took 4 guys a week of stripping before the boat was ready and safe to replate. We did note the hull althought oxidated had sweated under the foam.
Another project in 2006, remove aluminium hull plates on 29m sloop to rebuild 4 seperate intergral bilge fresh water tanks that had corroded thru. Same problem removing the insulation foam from around the tanks so we could safely weld and not have a 29m melt down.
Thanks to all for your interesting experiences and ideas
Old 11-02-2011, 11:00 PM
I had a call on this today. Usual problems to find insulation on hand anywhere.
There are fire retardant self extinguishing Expanded polystyrene sheets available that are manufactured for housing underfloor insulation.
Looks like would conform to all the standards. Here's one website :
http://www.homeefficiencygroup.com.a...5/Default.aspx
Another is called foilboard in Australia available in a range of thicknesses.
http://control.visionscape.com.au/Si...l_Brochure.pdf
Available cheap, very light. But we would never touch it because of the fire risk before.
Although I haven't properly looked into it it looks like it would do admirably now its self extinguishing common and cheap.
Mike Johns.
Old 11-03-2011, 11:33 AM
Northman Northman is offline
Rep: 137 Posts: 73
Originally Posted by daiquiri View Post
If this is just about thermal insulation, I'd rather go with sheets of closed-cell polymer foam - like Armaflex (or similar and cheaper brands
Daiquiri: Do you have names for other brands besides Armaflex here in Europe?
Much obliged!
Walter
Old 11-03-2011, 11:59 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
The first one that comes to my mind is K-Flex: http://www.kflex.com/default.asp?l=en
Italian brand, very good quality closed-cell foam in sheets and tubes, very similar to Armaflex. The prices can be seen in the attached pdf file (in Italian, sorry).
You can usually get around 30-35% discount on these prices. That's a curious way of doing business here in Italy - they give you a price list and then tell you that, being a builder, plumber or whatever, you are entitled to have 30-40% discount...
Then there is also Navycell, produced by Trocellen: http://www.trocellen.com/images/troc...c-navycell.pdf - similar in composition to Armaflex.
Cheers!
Old 11-03-2011, 04:43 PM
pdwiley pdwiley is offline
Rep: 531 Posts: 489
Mike, foilboard is sort of what I had in mind. As you may recall my house is insulated with layers of this stuff under the cathedral ceiling. I've been quite happy with it.
The only real caveat about the stuff is its potential to generate huge clouds of toxic fumes in a fire. OK, it might not burn in itself but a hot enough heat source will I think cause it to outgas quite badly.
As I need to add a bit more insulation to the workshop I might buy another sheet or 2 of the latest stuff and heat some offcuts up, see what happens.
The other caveat I've had is the exposed edges soaking up water but it might not be an issue, or easy enough to seal them after cutting to size.
PDW
Old 11-03-2011, 05:23 PM
daiquiri's Avatar
If you are worried about the possibility of fire in your workshop, then you should avoid polystyrene and polyurethane sheets; the former because easily flammable and the latter because it produces some very toxic fumes during combustion (Hydrogen cyanide and acrolein, for example).
You should use sheets made of polyethylene or polypropylene foam instead.
Cheers
Old 11-04-2011, 02:33 AM
If you are worried about the possibility of fire in your workshop, then you should avoid polystyrene and polyurethane sheets; the former because easily flammable ............
Slavi
Not any more, the Expanded polystyrene product we are talking about has a fire retardant and is self extinguishing. It's produced here en masse for the housing industry. You can read the flammability idex in the pdf I posted before.
Peter
All the foams gas off when the fire gets intense.
Mike Johns.
  #25
Old 11-07-2011, 10:49 PM
Rep: 41 Posts: 145
I've started research for supply of expanded polystyrene here in China, so far nada plus I need to test samples myself any I do find..suppliers here often make claim to non existing properties.
  #26
Old 11-09-2011, 01:40 PM
Rep: 137 Posts: 73
Cheers!
Daiquiri,
apologies for responding so late, I was away. Thanks a lot for the links! It appears they don't have dealers in Scandinavia, but I will contact them to make sure.
Cheers
Walter
  #27
Old 11-09-2011, 02:17 PM
daiquiri's Avatar
Think positive - it might be a good business opportunity for you.
  #28
Old 11-09-2011, 05:11 PM
Rep: 41 Posts: 145
Cheers
I had a look at the Italian Trocellen material, its very simular in composition and assembly to several Pyrotec products we use on our 12m to 20m HS RHIB in combination with accoustic barriers.
I intend using Pyrotec or Halyard composite thermal/accoustic in the engine space and 60m closed cell PU foam slabs glued against the skin for the accommodations length of the hull - bilge WL to sheer & deck heads.
The yacht owner, a very experienced yachtie intends sailing Antarctic and Southern Oceans.
My thoughts on how to drive yourself crazy choosing a hull design! Vulkyn Open Discussion: All Things Boats & Boating 70 09-12-2010 07:00 PM
Foam insulation and aluminium. Robbo Metal Boat Building 15 08-19-2010 07:08 PM
Any thoughts re: very thin aluminium ? SAE140 Fiberglass and Composite Boat Building 11 06-28-2010 07:39 PM
Free of charge, Steel - polyurethane foam -Steel insulation sheets rossgiles Fiberglass and Composite Boat Building 0 03-18-2008 06:43 AM
Foam for Insulation, not structure pairomedicsfish Materials 5 07-06-2006 08:28 AM
