  #31
Old 01-05-2010, 08:32 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
Originally Posted by Gaffers View Post
Whao fellas! There are some good ideas on here and some worthy contributions but masts are not worth getting in a tizz about ...
Strongly disagree! And you won't stop us going on and on about it anyway
... A few points:
I believe in epoxy usage and not using it inside a hollow mast would be foolish given the ease of application, durability and cost.
The mast will be removed from the dinghy when not used and stored in a dry garage after rinsing with fresh water.
Gaffers
Epoxy encapsulation will stop water from moving from one place to another. It can stop it getting in, but once it gets in, through a crack perhaps, it will stop it getting out again ...
Don't forget to rinse the inside of a hollow mast ...
Dances with Turkeys
  #32
Old 01-05-2010, 09:28 PM
Luckless Luckless is offline
Rep: 105 Posts: 163
Originally Posted by Brent Swain View Post
What is not saturated is like veggies in a plastic bag.Very rot prone.
Go down to the supermarket and find some dried fruit. See how long it takes to rot if you keep it well sealed.
  #33
Old 01-05-2010, 10:43 PM
Rep: 3125 Posts: 9,403
Brent, you are misinformed about epoxy, likely from others that are equally misinformed and disseminating lousy information. The amount of surface penetration is irrelevant to the waterproofness of an epoxy encapsulated piece.
You're under some sort of false impression that the wood inside an encapsulated piece will rot. It can't and you are smart enough to know why. What does rot need to thrive? Eliminate any part of the three things it needs and what happens? Encapsulated wood does precisely this and rot can't form, can't thrive, literally can't live. So, the penetration argument is moot. This has been born out in test after test and through decades of in the field use, across several industries other then marine.
Actually, urea formaldehyde adhesives have worked quite well, but they have draw backs, just like everything. It is more temperature sensitive than most typical marine laminating epoxy formulations, not less. In fact you can get epoxy formulations tailored to specific temperature requirements, where you're pretty much screwed with the formaldehyde glues. Secondly, the clamping pressures needed for successful joints with these glues can be difficult to say the least, particularly in the field with repairs. Lets not mention the glue line colors of these adhesives.
I'm sorry your perfectionist friends had difficulties, but given they likely paid attention to the misinformed folks such as yourself, it's not a surprise they had problems. This isn't unusual and unfortunately is a common problem. This is because of lots of stupid information, was put out by a few formulators that didn't know what they were talking about (Smith Brothers being one). Once someone tested their advertising hype, the truth came out and now there's a fair bit of understandable confusion. In fact, these products that once where the cat's meow to waterproof surfaces, are now used to plastize surfaces before real epoxy is applied or they're used solo, to permit/control moisture gain in structures dependant on swelling to work (plank seams for example).
I'm not sure what you're issue is with epoxy, but clearly you are in the minority. Epoxy formulators are popping up all over the world, but formaldehyde glue makers seem to be dieing off. In fact epoxy is wholesale replacing most adhesives and many mechanical fastenings as well. Those lead anchor shields are no longer preferred for hanger or stem bolt installations, but epoxy bonded holes work much better. They have to be done properly, just like the old anchor shields or things will fail, like the concrete roof slabs on the Big Dig in Boston last year, but this is pretty much true of most things.
  #34
Old 01-06-2010, 08:58 AM
58ketch 58ketch is offline
Rep: 10 Posts: 32
Not too very long ago..a few years back..I built a simple box/laminated tapered mast for a Hampton for a client who wanted internal halyards...while I thought that was overkill for the boat (the halyards really aren't THAT big a deal in a Hampton, anyway) what we did was champfer off the corners of each member and epoxy coat them internally as best we could and, then laid in a section of 1/2 pvc pipe with a gasket at the head.
While I've no way of knowing what the inside looks like now, I do know that he has no line wear issues beyond "usual and typical" for internal halyards and has no signs of rot that are visible.
We left a weep hole just above the step and it seems to drain adequately..fwiw.
  #35
Old 01-06-2010, 02:35 PM
According to Brent, you're "eventually" doomed. I'll suggest that what you did is a common technique and that it works well. Drainage holes getting plugged up are the biggest problem with hollow masts, not the fears Brent has. These holes get plugged because as lines run through their sheaves, very small amount of sand, dirt and dust get rubbed off and eventually find their way to the bottom of the spar, where they collect and eventually plug the drain holes. When I make new spars I make removable plugs, that have the weep holes in them. From time to time, you can remove these plugs, clean out any accumulated debris and reinstall them.
  #36
Old 01-06-2010, 03:57 PM
Member
Rep: -33 Posts: 951
I've used formaldehyde glue in the dead of winter, then put the glued pieces in a bucket of water for several more years with no delam or other problems. I've seen epoxy laminated parts fall apart, in a workshop, without having seen any outside conditions. A commercially made a laminated bow I had, laminated with epoxy , made by Hoyt Archery, fell apart.
A wooden mast has a lot of fittings bolted to it, which can enable water to come in . Most of the time it is well enough sealed, but sometimes seals fail , just like they do in commercially made "Waterproof " autopilots which if left outside, all eventually fill up with water. You say some things on a boat can be made 100% failproof watertight? ******** . I've been cruising too long to still be that naive. Some obviously haven't
  #37
Old 01-06-2010, 04:12 PM
Rep: 105 Posts: 163
And there was a big complaint at my school awhile back about the expense they went through to put in new counters and the complaint of the use of a formaldehyde glue used. All the counter tops were buckling and pulling apart.
Do you have a point? Do you have data?
  #38
Old 01-06-2010, 04:38 PM
apex1
Oh Brent, Brent,
I have seen a house burning down completely. The entire family killed in their beds.
Brickwalls cracked from heat, a refrigerator, tall as a man, was molten to the size of a shoebox. Nothing survived the fire. Except a bundle of old magazines (paper!) and a little doll! The doll still had the artificial hair and a red little dress. The most bizarre picture I can remember.
Must I assume now, that plastic dolls are less vulnerable than humans? Paper is the better material for making refrigerators?
Formaldehyde glue.........you´re kidding.
  #39
Old 01-06-2010, 05:01 PM
Rep: 10 Posts: 32
....opinions are like, well, you know....
I've been a woodworker for over 40 years and in that time I have seen failures in hide glue, epoxy , resin and chemical glues. I have never seen a failure that could be attributed entirely to the adhesive, though. "Operator error". inadequate or uneven clamping, extreme heat or cold either during laminating or afterward, etc. have ALWAYS been present.
NOTHING is perfect 100% of the time nor is any process BUT, I can honestly say that with the possible exception of water and flour paste I have the utmost confidence in most adhesives and, since the advent of epoxy, even more. The ONLY adhesive I trust beyond epoxy (where applicable/ pick your brand) is Resorcinol.
Do I think that really matters? No, I have found all of the adhesives when used as directed to be most forgiving and durable in competent hands...the latter being of the UTMOST importance.
As for my little Hampton mast...I'll wager it outlives me.
  #40
Old 01-06-2010, 05:49 PM
aka Terry Haines
Gaffers: sorry about this; don't worry - the thread will die of old age eventually. Hope you got what you wanted. Happy New Year!
Dances with Turkeys
  #41
Old 01-07-2010, 02:11 PM
Member
Rep: -33 Posts: 951
I have only 40 years experience, much of it offshore, in all kinds of conditions , using both.
wooden mast icefang45 Boatbuilding 3 05-17-2009 11:48 AM
Wooden mast??? Laser@pcrf.org Sailboats 8 02-11-2009 03:44 AM
wooden mast wanaco Materials 8 07-05-2008 11:34 AM
how to's "building a wooden sailboat mast" fishweed Wooden Boat Building and Restoration 8 12-23-2006 07:32 AM
Building a laminated wooden Mast Dominique Sailboats 14 06-02-2005 02:34 PM
