| Wood Boat seams openning up after 38 years I have a modified Herreshoff 28 that my father built. The problem is the topside hull seams are opening up. The boat is 38 years old and this has never happened. If fact most people believe the hull is made out of fiberglass. I repaint the topsides every 5 years. The hull is stripped plank with mahogoney 7/8 thick, concave/convex, about 1 1/4 inch high, glued, nailed every 6 inches down thru the other planks with a 6 inch finish nail and then screwed into the frames . The boat is sailed on Lake Erie so it is stored in a garage from Oct to May every year. It has never been stored outside. Nothing has changed in the way we haul the boat. The only thing different is the very mild winter for Ohio. 30 - 45 degrees versus the normal 15-30 degrees. Any suggestion as to what is causing the problem? |
| Some factor has changed even if you don't see it------ it could be that the hull has progressively gotten worse and you only now have begun to notice it. It may also have dried excessively, something that could have been avoided if the hull was parked over dirt (preferred) rather than asphalt As wood ages it gradually loses its elasticity. It becomes more necessary to concentrate on preventing excessive drying. The winter storage should be dark and damp. A bit of natural ventilation is good but too much can dry the hull out. |
__________________ "All one has to do is follow the plans and build in no permanent leaks." -Charles Minor Blackford, on the simplicity of building flat bottomed boats |
| Ask about your difficulties over at Wooden Boat Forum. They're more informed than we dinosaurs here. ![]() ![]() http://forum.woodenboat.com/index.php Good luck/
__________________ Whilst entitled to your own opinion, you are not entitled to your own facts! |
| Reply from Sweep Thanks everyone. I was thinking along the same line of the garage being too dry. We have a humidifier going. The whole thing is very wierd. I have worked on this boat all 38 years and the hull has always been very sound. Even the bottom only requires minimum caulking. The bottom does not seem to be effected. Only the topsides. Its as if the seams are being pulled apart from the top. Thanks for the info. Rob Chimney |
| Is the hull properly supported?
| It sounds like a structural issue, not a planking interface issue. It's more common to see this sort of thing on other build types, such as carvel or lapstrake, but it can happen to traditionally built strip planked hull too. The usual suspects are frame relaxation/cracks/breakage and sheer clamp/shelf fastener looseness. Both of these issues, will permit the bilge turn to sag, as a result of the lose of frame assembly stiffness, either at the top of the "flange" (sheer clamp/shelf) or along the turn of the bilge (athwart frame work). Considering the hull shape of the H-28, the common areas for this to occur would be aft, just above the LWL and progressing forward and likely upward toward the bow, eventually fading out in the most forward, straight sections. Second areas to look would be the garboard seam, where some movement may be occurring as a result of the new hull shell strains. Lastly I'd disagree about the "we dinosaurs here" comment. Though I was born shortly after their catastrophic demise, I don't consider myself as self important as many over at WoodenBoat seem to promote now. There are a number of skilled members there, but it's become increasingly more difficult to tell who they might be, unless you know the posters at some level and what is coming from the "bilge" and what isn't. And God forbid you might disagree with the "regulars" over there, as castration or censorship is the usual approach any more. |
| ....emmm yep I agree, they are too "precious" there for me too, only lasted a few weeks to realise that it was like a Jaguar Concourse show........
| i thought it was a big statement for pericles to make, assuming that because he doesn't know about the subject that none of the professionals on this forum would either.
__________________ brendan . |
| Its all to do with Globle warming and the rise in sea levels !! you are closer to the sun than before !! Makes a differance !! ![]()
| I have no idea why it waited 38 years to start opening up, but I can see the slack-jawed expression on the face of the OP when he first noticed it.... |
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Fishing boat refit and conversion at 56 years old | GAZZABO | Wooden Boat Building and Restoration | 0 | 08-01-2011 04:29 AM |
| Boat designer gets 3 years....negligent | pistnbroke | Boat Design | 16 | 07-19-2009 05:08 PM |
| 10 years for building a steel sailing boat!. | Alain POIRAUD | Metal Boat Building | 6 | 08-13-2008 04:57 PM |
| below water seams on wooden boat | 64centuryhelp | Materials | 6 | 11-17-2006 12:25 AM |
| Below Water Seams On Wooden Boat | 64centuryhelp | Wooden Boat Building and Restoration | 8 | 02-17-2006 10:29 AM |
