Old 02-21-2006, 07:33 PM
McLellan McLellan is offline
Rep: 10 Posts: 2
Winch line entry angle
Hello, I am a boatbuilder working on a large sailboat. I have been told the appropriate line entry angle to a deck winch from a block is 5-10 degrees(below the horizontal). Reason being, if the angle is more-the line will chafe on the skirt and wear on the winch because it's not pulling efficiently. If the angle is less, the line will over-wrap up the drum. This makes sense, but in our case to achieve just 12 degrees requires the footblock to be mouted on a tall base 7"-8" above deck. We can't move or tilt the winches any so this looks like our only option. Any thoughts?
Old 02-21-2006, 11:30 PM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
How about a u or v shaped roller mounted in front of the winch
Old 02-22-2006, 12:44 AM
RHough's Avatar
RHough RHough is offline
Retro Dude
Rep: 714 Posts: 1,622
Originally Posted by McLellan
... but in our case to achieve just 12 degrees requires the footblock to be mouted on a tall base 7"-8" above deck. We can't move or tilt the winches any so this looks like our only option. Any thoughts?
Are the winches and turning blocks where the designer drew them?
If the designer couldn't get something as simple and obvious as fairleads to winches right, what does that say about the rest of the design?
I'm sure mounting a footblock that has double the sheet load 8" off the deck will not be a structural challenge.
Don't worry, there are hundreds of boats out there (both production and custom) that don't have decent leads to the winches. If the designer didn't get it right, at least you are trying to make it as right as you can.
Proud supporter of The Far Kurnell Cat Racing Team
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
Old 02-22-2006, 10:06 PM
Rep: 10 Posts: 2
Footblock tower
Thank you RHough and bhnautika, at the shop we all seem to have some reservations about the designer. You are correct, this is only one of many issues we've been dealing with. We can't use any rollers because the winches are perched on the edge of the aft house and the there's no room. I can't wait to see this double footblock on the side deck, it's going to be a tower.
Old 02-23-2006, 01:25 AM
Rep: 499 Posts: 489
McLellan I had a similar problem being close to the edge .I made the base of the roller/fairlead part of the winch base so it was all one piece.
anchor winch motor Peter Baker Electrical Systems 2 07-13-2005 10:32 AM
sailboat winch drill adapter bit TheCranker Marketplace 0 12-12-2004 08:50 AM
hollow entry? rickc Boat Design 15 10-28-2003 06:35 PM
New Entry IOVH Option One 2 03-14-2003 04:13 AM
