Old 05-07-2003, 10:38 AM
Ward Ward is offline
Registered
Rep: 25 Posts: 29
Why not give hulls 'negative camber' on a cat?
Im just curious why on a catamaran, the hulls, looking head on have paralell centerlines. Why not tilt them inwards (the tops of them) just a bit? Since a catamaran is going to be listing during sail, the hull that its riding on would then be vertical in the water. Im sure there's probably some reason they're not made this way though, otherwise someone would have already done it
I work on cars alot, and i know that an easy way to make a car handle better is to give the front tires negative camber, where the tops of them are farther inboard than the bottoms. During a hard turn, when the car leans a bit, the inside wheel will be vertical and have more tire touching the ground. Would this not benefit a catamaran any?
Old 05-07-2003, 04:29 PM
Pieetry Pieetry is offline
Rep: 10 Posts: 16
maby when u sheet the sheets althe way in its going to make hte main be above centerline, ass everything is oriented around the direction the hull is going
Old 05-07-2003, 07:33 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 645 Posts: 1,723
Many (most?) fast cats have canted centreboards, which gives the same effect, so to speak. Since the section of the hulls is close to circular, the heel won't matter much, as they should be sailed pretty flat (one hull flying, but only just, to keep the sail as upright as poss)
Steve Baker
Old 05-07-2003, 07:54 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
The A-class cats have been using canted hulls for some time, and some cruising cats have canted hulls. Trimarans also use canted hulls for the amas. It's actually a common practice these days.
Tom Speer
Old 05-08-2003, 02:22 AM
Registered
Rep: 25 Posts: 29
Hmm, I guess they only run a couple degrees of camber then, because from all the racing cats I've seen in pictures, they just look paralell. they must only run a couple degrees.
Old 05-08-2003, 06:23 PM
SailDesign's Avatar
15 degrees on the last A-Class I worked on.....
Old 05-12-2003, 01:27 AM
For example this cat posted in the gallery by b_rodwell: http://www.boatdesign.net/gallery/sh....php?photo=168
Old 05-12-2003, 07:26 AM
SailDesign's Avatar
Guest says "For example this cat posted in the gallery by b_rodwell:.........."
Except that his centreboards are vertical, where I would have expected them to follow the hull cant.
Old 06-14-2003, 03:19 AM
robl robl is offline
A Class cats have used canted hulls for many years. Some have been up to 15deg. but most have now settled on around 5deg. the downside to using canted hulls is that when both hulls are in the water they present an assymetrical shape, which can be slow.
Wetted surface area - approximate formulas Mike D Boat Design 11 08-25-2005 11:00 AM
Thickness of aluminum cat hulls? JonathanCole Metal Boat Building 4 08-18-2005 10:17 PM
Wormhole Drive Propulsion!. trouty Boat Design 31 06-13-2005 10:51 PM
1) Are hulls same shape in a Cat 2) hull spacing Will Boat Design 7 05-05-2004 10:41 AM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-25-2002 11:26 PM
