Old 01-25-2010, 12:51 AM
Grant Nelson Grant Nelson is offline
Rep: 159 Posts: 203
When NOT to use full length battens?
Hi,
My original question was going to be 'when should I consider full length battens' thinking that the answer would be based on some percentage of roach to main sail area, or aspect ratio, or something.
But then I scanned a few sail maker web sites and it seems that full length battens have many advantages, even when you do not have much of a roach. For example holding the sail shape, and perhaps for most of us, increasing the life time of the sail. The only down side seems to be that they tranfer more compression to the luff, and the hardware there, with a chance of jamming, and when running off the wind, you have the chance of a 'step' or V forming near the mast.
In some cases you can use a mix, some full battens up high, and 'normal' down low.
So, now my questions is: when you you not want to use full length battens? Of course you can always answer my origional question if that is eaiser.
Thanks!
Grant
Old 01-25-2010, 05:24 AM
Rep: 1493 Posts: 7,447
You don't want to use full length battens when the rig was not designed and built for them.
Old 01-25-2010, 06:26 AM
Rep: 159 Posts: 203
I am not sure what I can do with that reply Gonzo.
Does it help to say this is not for a existing boat, but for a new design?
Or, let me ask, what are the particular rig design aspects that are required for full batten sails? I have to admit I never though about it but can only think that you need non-jaming mast track hardware...
Old 01-25-2010, 06:40 AM
Kaluvic's Avatar
Kaluvic Kaluvic is offline
New guy
Rep: 32 Posts: 123
Not sure why...is it because of structural considerations?
Not sure I would agree.
Few things should be taken as seriously as the pursuit of pleasure.
Old 01-25-2010, 08:14 AM
Steve W Steve W is offline
Rep: 360 Posts: 686
Gonzo, could you please elaborate on what structural differences there would be with a rig "designed to use full battens" vs one that is not ,i for one am not aware of any other than perhaps some retrofit items such as articulating cars.
Steve.
Old 01-25-2010, 08:55 AM
Clearerance with the backstay, adequate sail slides or bolt rope, batten pockets, sail track,
Old 01-25-2010, 09:11 AM
Kaluvic's Avatar
New guy
Rep: 32 Posts: 123
When I think of going to a full batten....the length of the batten increases toward the mast not the back stay...
Depending on the track you have, batten cars may be added.
I think if you were to go to a full batten its a given that the batten pockets would be modified.
So am I correct that your concerns about the rig are not structural?
Old 01-25-2010, 09:40 AM
Rep: 360 Posts: 686
Those are all sail related issues,not anything special relating to rig design,while hardware manufacturers would like us all to have expensive car and track systems i have noticed that the F series trimarans have always had large full battened mains without such hardware,in fact they really cant as they roll the sail around the boom to reef or furl,they must work ok as they have stuck with it for decades.
Steve.
Old 01-25-2010, 10:02 AM
Kaluvic's Avatar
New guy
Rep: 32 Posts: 123
I'm certainly no expert....but I can't think of any time that a full battened main would not be preferential.
Old 01-25-2010, 10:21 AM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
Originally Posted by Steve W View Post
....in fact they really cant as they roll the sail around the boom to reef or furl,they must work ok as they have stuck with it for decades.
Steve.
That they roll sail around the boom is probably the reason why the batten ends don't get stuck. Both ends of the batten are being pulled down more or less evenly.
It's when they are pulled down unevenly they are most likely to get stuck. That is unless they have some kind of roller or slide.
That just goes to magnify Gonzo's point.
The rig must be originally designed for them.
I am highly suspicious of the terms 'perfect' and 'best'. I favor the terms 'inadequate', 'adequate', and 'better', instead, with the first of these closest to being an absolute.
Old 01-25-2010, 10:38 AM
Kaluvic's Avatar
New guy
Rep: 32 Posts: 123
Why....there are batten cars for a variaty of slides...I still dont get it.
Old 01-25-2010, 11:04 AM
Rep: 3125 Posts: 9,403
As in everything with yacht design, full length battens have their issues too.
A big one is weight. Once you count up all the cars, additional related hardware and the battens, you've now increased weight aloft substantially.
Next on the list is cost. Price out a retro fit for a full up system, compared to a replacement bolt rope or slide sail with conventional battens. When your ass cools down a bit we can talk.
For a cruiser, full battens may not be as logical a choice as the 'round the cans guys. The cost, the maintenance, the wear and tear, plus the weight just don't seem as conducive to leisurely sailing.
Reefing is another well known problem. So much so they compromise batten position to accommodate roller booms.
Binding and jamming use to be big issues, but has for the most part been engineered out of the new systems, though, don't keep up on the maintenance and you'll wish you had.
Old 01-25-2010, 11:21 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
"When NOT to use full length battens?"
first thought up, rulings, rulings like AC dont allow full battens
but offcourse there is much more on battens
Old 01-25-2010, 12:06 PM
I've known several people that got rid of full battens in cruising boats because of the amount of wear and maintenance of the parts.
Old 01-25-2010, 12:24 PM
Kaluvic's Avatar
New guy
Rep: 32 Posts: 123
That’s interesting...and makes sense...most cruisers I know would sacrifice some performance if there is a big maintenance bullet to bit for having it.
Good stuff...thanks!
Transition joint or full length butt joint unseen wombat Wooden Boat Building and Restoration 12 06-05-2011 12:16 PM
battens and framing question wudenbote Wooden Boat Building and Restoration 9 09-10-2009 05:07 PM
Full-length keel daiquiri Boat Design 21 05-25-2009 10:26 PM
Wing Mast Battens earthsail Multihulls 1 10-07-2008 10:09 AM
On Battens Dave Fleming Wooden Boat Building and Restoration 4 10-30-2003 10:16 PM
