#46
Sounds like someone made a large mistake with that sail design if they were planning to buoy race under IRC... |
#47
#48
I suppose I do know that there not all the same, but had not thought about in that way. On the full on big roach boys, they are depowered quite quickly by dumping the sheet rather than the track (trying to grind them back in afterwards when the gun goes off) As far as this mast breaking bit is concerned, the only real difference I have noticed is that the fully batten rig (especially the big roach) really does power up a lot quicker and I have been on board boats that have broached hard over as they gybe cos people where not concentrating. and I have seen masts go (not sure where they broke) but they are more due to operator incommpitance rather than the fact they where fully battened. Kim |
#49
__________________ Gonzo |
#50
| All this effort and you still cannot tell us the specifics of your claim of firsthand knowledge. Not one of your links even anecdotally proves your point. Every post you make seems to trump your earlier posts in bizarre nature. Quote: If you knew about Laser sailing you would know about this failure mode. It is quite common. This has nothing to do with your false claims. FAIL. Quote: This has nothing to do with your false claims. FAIL. Quote: This has nothing to do with your false claims. FAIL. Quote: This has nothing to do with your false claims. FAIL. Quote: This has nothing to do with your false claims. FAIL. |
#51
| The Sharpie 500 class was designed for full battened mains. The wear and tear on the mast track and sail lead owners to change to short battens. These were cotton sails and wooden masts. The groove for the bolt rope would wear and split. The forward section of the pocket would wear and the battens poked through. The battens would also snap if flogging in strong winds. They were made of ash or oak.
#52
Yes, this post of yours does trump your last one in the bizarre factor. At least you are consistent. By the way, you have yet to tell us the specifics of the retrofits to full battens that you have seen that caused masts to break. Why are you avoiding this? |
#53
| I'm afraid you will make me cry again Paul B. I can't sleep because of you being so mean to me.
#54
| Don't know if it's done or not, but imagine if, instead of a single backstay, there were twin stays attached to a spreader at the top of the mast... |
#55
| Some boats have a fiberglass batten that keeps the slack of the backstay from getting hooked on the sail. However, you need to loosen the backstay and tighten it when you tack. The tension on the backstay keeps tension on the forestay and also controls mast bend.
#56
You obviously don't understand the basics of how that type of rig is set up and works. |
#57
| Paul B has a little problem. I can send some cheese to go along with your whine. Post something relevant to these threads.
#58
| A big crane can work sometimes. |
#59
| ukhalsey - a realy respected sailmaker states this abut full lenght battens Quote:
__________________ Lithuania |
#60
The sail plan also modified to suit. No big deal if the're all hired guns but otherwise...
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| Transition joint or full length butt joint | unseen wombat | Wooden Boat Building and Restoration | 12 | 06-05-2011 12:16 PM |
| battens and framing question | wudenbote | Wooden Boat Building and Restoration | 9 | 09-10-2009 05:07 PM |
| Full-length keel | daiquiri | Boat Design | 21 | 05-25-2009 10:26 PM |
| Wing Mast Battens | earthsail | Multihulls | 1 | 10-07-2008 10:09 AM |
| On Battens | Dave Fleming | Wooden Boat Building and Restoration | 4 | 10-30-2003 10:16 PM |
