Old 02-27-2005, 01:21 PM
pengreg pengreg is offline
Rep: 40 Posts: 52
Wheelhouse
I have a 35' steel designed by Colin Childs and built in NZ. She has an entirely flat deck and aft cockpit, and although a cutter rig the forestay is not on the short bowsprit but back at the apex of the bows. I would like to drop the cockpit floor (still well over waterline) and enclose the cockpit in a low wheelhouse with side access - swop the tiller (stern hung rudder) for hydraulic steering. Add stern davit, tender and mainsheet track to house roof and take the forestay to the end of a bowsprit where it belongs..
That said I know just about enough on boat design to know how little I know..
So if anyone has a helpful comment or caution I would really welcome it.
Old 02-27-2005, 01:47 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2006 Posts: 1,638
The addition of a pilothouse and dinghy over the stern means added weight high and aft. This will alter your trim, she will be down by the stern, which is not good in most boats. This will be dependent on hull form and current trim, and there may be ways to minimize the trim change by moving other weight forward.
The mainsheet on the house top will be an engineering challange, possible, but if you can avoide it by moving the sheet horse forward it would be lighter and stronger. Then again maybe you are up for building the pilothouse of foam-cored carbon?
All the best, Tad
Old 02-27-2005, 11:01 PM
Plumbtex Plumbtex is offline
Rep: 10 Posts: 18
Unless I'm mistaken ,which is not only possible but likely, the forestay for a typical cutter rig belongs at or behind the apex of the bow. A jibstay whose primary function is for setting sail and not for supporting the mast would lead to the end of the sprit. Moving the forestay might weaken the rig if the sprit 's not up to the task.
Old 02-28-2005, 02:41 AM
Rep: 40 Posts: 52
What if the house roof was low - seated height only with a hatch over the wheel for standing observation. I was planning on good old 3mm steel and hoping this would handle the main? What concerns me most is my plan for enclosing aft with some sort of side access - everything I see is open aft? I felt that this may afford some protection from a following sea. - thanks Tad
Sounds unlikely to me - my mistake, the jibstay is at the bows and forestay is back on deck? At the moment the sprit has nothing - thanks Plumbtex
Hey - maybe by moving the power forward to the end of the bowsprit I will counter the additional weight aft?
Old 03-11-2005, 11:18 PM
asathor's Avatar
asathor asathor is offline
Rep: 10 Posts: 154
Get help.
Get a Designer to help, there are plenty around this board.
Ted Brewer has some excemplary laid out pilot house designs - you can find pictures in Yachtworld . com used listing.
What is the hull type ?? There are no traces of your boat on the web.
I know this much, you can't fix a hull thats dragging it's but by changing the sailplan. Raise the saloon to keep the weight centered and install a forward stearing station - it could be electronic if you keep the outside wheel.
May the wind blow briskly in your sails!
Old 03-13-2005, 03:35 PM
Semi-Newbie Posts Often
Rep: 10 Posts: 857
Read Brewer's "understanding boat design." It'll help you. But I have to say, you might want to change the rig entirely unless you have the skills (design, engineering and manufacturing) to make a pilothouse under a cutter. Probably, moving the forestay would change performance and the integrity of the rig. That's my 2 cents.
Signed-
mackid068
_________
Sailing (n.) The art
=/\= A sailing Trekkie!=/\=
Old 03-14-2005, 02:33 PM
Rep: 40 Posts: 52
Thanks Asathor and Macidd - I have some detail under a new thread - "need designer"
advantages of fwd wheelhouse longliners hirantha Boat Design 5 09-27-2005 11:42 PM
advantages of forward wheelhouse longliners hirantha Fiberglass and Composite Boat Building 2 09-22-2005 08:11 AM
Wheelhouse windscreen design Steve Gray Boat Design 6 08-25-2003 02:57 AM
the 1 hour sketch 8knots Option One 11 03-23-2002 08:52 PM
the 1 hour sketch 8knots Boat Design 11 03-23-2002 08:52 PM
