  #31
Old 11-21-2006, 09:10 AM
PI Design's Avatar
PI Design PI Design is offline
Rep: 309 Posts: 604
So has short and fat. Designing sailboats is the second oldest profession, there's not much hasn't been tried before.
  #32
Old 11-22-2006, 12:57 PM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
Originally Posted by Doug Lord View Post
Sure would be interesting to see what a two person bi-foil mono or multifoiler would do...
It's completely feasible to do such a boat using this sail area between 22-24' with upwind foiling capability in a wide range of conditions.Hmmmm...
I know you've seen JPZ's 18' foiler, Doug. For anyone who hasn't, check out http://boatdesign.net/forums/showthr...t=13513&page=2
It seems to me the boats to beat, in the near-shore contest, will be sailboards & Ketterman hydrofoils (a.k.a. Hobie Trifoilers). But that shouldn't stop others from trying.... sounds fun!
I'd like to nominate Bob Esmer to create the trophy: www.bobemser.com
  #33
Old 11-22-2006, 01:40 PM
Originally Posted by PI Design View Post
I therefore believe that a relatively long hull can help significantly, up to the point where beam and/or draught have to be reduced (to maintain a constant displacement) to a level where stabilty and motion suffer.
Metacentric height varies with Beam^2 / Fairbody Draft.
As long as that ratio remains constant, you should be able to make your boat as long as weight/structural considerations allow without having a big effect on stability.
Each time the beam is halved, the draft needs to be quartered, meaning you will only have 1/8 the midsection area. Therefore you only halve the beam if you are increasing length by a factor of 8 and maintaining the same displacement. I want to say beam would scale with 1 / the cube root of the length scale factor, while draft would scale with 1 / the square root -- but I'm not sure that's exactly right. Anyone want to take a shot at writing the function correctly?
  #34
Old 11-22-2006, 01:52 PM
Doug Lord
trophies and hydrofoils
Good on the trophy if it didn't cost about the same as one of the boats.
The Ketterman or Bradfield three foil foiler would have a good chance inshore in winds over 15; the monofoiler or "bi-foil tri" in lighter and probably rougher conditions. The Ketterman and Bradfield boats don't come close to the pointing ability of already existing monofoilers but their top end speed may be higher. I've seen a Rave up close in 15 knots and video of a Moth in similar conditions-I think the Moth would beat a Rave in 5-20knots with a 9mē sail particularly around a course where the monofoiler's superior upwind ability would be a major player. I think a 24-28' super Moth(either bi-foil tri or canting keel foiler -see sportboat thread) that had been debugged and refined in a two boat test program would be the fastest boat with 430 sq.ft.in inshore conditions and quite possibly in a relatively peacefull transpac as well. If the conditions were less than 50% foiling conditions Robs boat wins hands down in the ocean.
I urge anyone- who hasn't already- to read Rob Denney's technical description of his 50' proa -link in his last post.
  #35
Old 11-23-2006, 04:12 AM
SuperPiper SuperPiper is offline
Men With Little Boats . .
Rep: 58 Posts: 277
Each time the beam is halved, the draft needs to be quartered, meaning you will only have 1/8 the midsection area. Therefore you only halve the beam if you are increasing length by a factor of 8 and maintaining the same displacement. Beam, in other words, would scale with the cube root of the length scale factor, while draft would scale with the square root.
Stephen, could you please repeat that slowly for me? I am cranium-challenged.
  #36
Old 11-23-2006, 04:18 AM
PI Design's Avatar
Rep: 309 Posts: 604
I agree with what you are saying, but the trouble is that maintaining a constant B^2/T whilst increasing length results in a lighter displacement (for a constant block coefficient). You therefore have to carry less lead, assuming the boat is being built as light as possible anyway - so there is no chance of using lighter hull materials. With only 40sqm of sail, you don't need that much ballast, but obviously there comes a point where you will have too little. Without having done any calcs, I guess this will be when L = 35-40ft.
  #37
Old 11-23-2006, 04:32 AM
PI Design's Avatar
Rep: 309 Posts: 604
Sorry, SuperP, I didn't see yuor post when I put mine in. What Stephen is saying is that you don't halve the beam when you double the length, to maintain a constant displacement or initial stability. You only halve the beam when the boat is eight times longer. The problem (that's too strongh a word, but I can't think of a better one of the top of my head) is that stability and displacement don't scale the same, so you'll need to change the block coefficient (and hence hull form) to keep the two balanced.
Is that right Stephen?
  #38
Old 11-23-2006, 06:48 PM
I was assuming a constant block coefficient, a constant displacement, a constant VCG, and that we're talking about a monohull sailboat. The main point is the first, about maintaining a constant B^2 / T to maintain comparable form stability. The implication, as I see it, is that if you're thinking about increasing length and decreasing midsection area, fairbody draft (T) should diminish faster than beam (B).
When I say fairbody draft, I mean hull draft, not counting the keel. And what I'm really referring to when I speak of its diminishing is all vertical offsets (waterline to outer surface of hull) diminishing by some factor.
I've made an edit to my earlier post because I'm not sure I had the math exactly right. Not your fault you were confused .
  #39
Old 11-24-2006, 11:50 AM
I did, on your advice Doug, and I approve. I'm liking those Harryproas quite a bit.
As the site itself notes in discussing the most radical of the proas <http://www.harryproa.com/Texel/texel.htm>, though, the achilles heel is lack of ability to move weight aft, resulting in the bow being pressed if pushed hard.
But perhaps this is an opportuinty for a design breakthrough, esp. where Rob is in Australia. Is there an active Moth fleet where you are, Rob? Sensor wands and T-foils on proas might be the answer! Another possibility might be a kite sail or a canted sail to leeward like http://www.boatdesign.net/forums/sho...&postcount=406... the idea being that the sail pulls & lifts rather than pushing the bow down (of course).
Quite a group of innovators down under.... Lindsay Cunningham (Yellow Pages Endeavour), John Ilett (Fastacraft), Andrew McDougall (KA Sails), Rohan Veal and the other Moth sailors, Leo Lazauskas on theory, and Rob Denney with his proas. Get all those guys in a room and put a challenge like this in front of them...
Hey wait a minute, Rob, you're the guy who started this thread! Sometimes it takes me a while.
No relation to the proas, but the general direction of this caused me to think of the boats in these photos:
What would you do with 40 sqm/430 sq' of sail?-g-32.jpg  What would you do with 40 sqm/430 sq' of sail?-gerr60a.jpg
  #40
Old 11-25-2006, 06:02 AM
rob denney rob denney is offline
Rep: 382 Posts: 362
[quote=Stephen Ditmore;115352]I did, on your advice Doug, and I approve. I'm liking those Harryproas quite a bit.
G'day,
I am in Perth, where the foiler moths originated, so yes there is some potential. However, I think I would be way out of my league with those guys. I'd be happy to just sit and listen.
We are part way through the design of a 16' proa foiler. Some novel problems which normal boats don't have, and some easy fixes for some of their problems. Should be fun when it finally sails.
Another solution to the lack of fore aft stability is extreme length, which is why my 40 sqm/430 sq' of sail is on a 15m/50' hull. If I can keep it light enough, light air performance should not be a problem, and once it starts to blow, we should be pretty quick. SA/wetted surface is 3.8 at rest, 4.3 with the hull flying.
regards,
Rob
  #41
Old 11-25-2006, 09:53 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Limiting sail area drives the class to very high aspect ratios and does not allow for adding sail area for downwind legs. Basically you're talking about an A - D class catamaran without any constraints on the hull. The American open-class landyacht classes are of this type. The tall rig leads to a large chassis to counter the heeling moment, and you end up with a large, spindly, lightweight craft.
I think an even more interesting class would be one that only had a limit on the height of the mast. This would allow you to vary the sail area as appropriate. The limit on mast height also limits the height of the center of effort, and that naturally limits the beam because there's no point in making it too wide.
The interesting trade here would be efficiency vs area. There may be an optimum area to drive long, fine hulls. More sail area would add parasite drag and weight, cutting into the L/D and limiting speed. For example, my landyacht is faster with its small sail than with its big one in all but the lightest winds.
Tom Speer
  #42
Old 11-27-2006, 07:41 AM
Rep: 382 Posts: 362
G'day,
How large, spindly and lightweight the craft become is what I am interested in. Racing with crew mid summer on a short course in San Francisco and sailing solo across the Pacific will ensure that the boat has some robustness, and may penalize ultra high aspect ratio rigs.
However, thinking about what I would design for these two races with a mast height limitation, I don't think I could do much better than a very long, light proa with a single sail. My mast is 11m/37' off the deck. F 27 tri, Stilletto 27 cat, Thompson 770 sportsboat, Hobie 33 keel boat are all a little higher than this and I will be disappointed if I don't beat all of them on all points of sail in most, if not all, breeze strengths.
I have a lot of respect for your opinion and knowledge, I would be very interested to hear your thoughts on what would be fastest under both rules, for both or either, courses.
Curious about your land yacht. Is the smnall rig advantage due to a stability limit, or a sail shape control limitation? Is there anything you can change to make it faster with the big rig? If nothing, does it follow that small land yachts beat big ones? If so, what is the optimum smallness? These are genuine questions, I know next to nothing about land yachts.
regards,
Rob
Looking for Used Main Sail jag459 Marketplace 3 08-19-2006 10:45 AM
sail TV Caldera Boats Sailboats 0 04-20-2006 02:49 PM
name that sail revned Sailboats 14 03-29-2006 01:58 PM
force from a sail man308 Sailboats 5 02-20-2004 10:44 PM
Sail Forces...again nemo Sailboats 5 02-15-2004 08:42 PM
