| What is the difference between "fixed fiddles" and "hinged fiddles? What is the difference between "fixed fiddles" and "hinged fiddles? |
| a fixed fiddle is a concrete double-bass.
| pls explain more... |
| A fiddle, as you no doubt know, is a guardrail used on a table during rough weather to prevent things from slipping off. They can be fixed in place or hinged so they can be lowered out of the way when not required. There's a pic of a fixed one here http://www.classicmarine.co.uk/prodt...type=66&ph=cat I haven't found a pic for a hinged fiddle. They are used on cruise ships and liners so they can be out of sight in calm conditions and raised if weather is heavy enough that the ship's stabilizers can't handle the load, as sometimes happens in a storm (speaking from experience). They use neat hinges that allow the rail to vanish under the edge of the table.
| No. I have not heard of a fiddle on a block, but I think it is the eyelet at the top. There is sometimes one at the bottom, called a becket. Try contacting the supplier.
| It just means the attachment point on the block's end is either swivelling or not. |
| heh I know this alone! I ask what is difference when I USE fixed and what when I use hinged fiddles! What happen if I use fixed fiddle (bad and good)? and What happen if I use hinged fiddle (bad and good)? And what are better for some purposes... |
| Wether you need a fiddle block is a seperate question from wether you need a fixed or hinged strop. Fiddle block are used in rigging situation where the block must stay in the plane of the load and not capsize as a double block could when slacked, such as in multi-part topping lifts, backstay or preventer tackles, runners, etc. A hinged, or swliving strop, is used on a block normally mounted where the pull is not from a single plane. A fixed strop is used either when the direction of pull is fixed to a single plane, or the block is on a pendant.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Right, and that should be obvious. So the word, "fiddle" needn't have been mentioned. The question ought to have read, "Why would one have a swivel on a block, and would a fixed eye sometimes be preferable?" A lot of the time, the situation doesn't call for anything more than a loop in the strop, called an eye. So the block in that case is less expensive and also more reliable without the complication of those extra parts. |
| 16-18' "Sit-in" Planing Monohull ("Trapwing") | Doug Lord | Sailboats | 124 | 04-23-2009 05:14 PM |
| CMD "project Zeus" VS VOLVO "IPS" | gerard baladi | Pod Drives | 13 | 09-10-2007 09:23 PM |
| Boat "workshop" including a "testing tank" | zmfmd | Open Discussion: All Things Boats & Boating | 0 | 08-08-2007 04:43 AM |
| "Saw Cut" vs "Shear Cut": What is the difference? | westsail42 | Metal Boat Building | 5 | 04-26-2007 08:24 PM |
| Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" | Vibtor | Software | 0 | 10-02-2004 02:03 PM |
