Old 09-20-2009, 09:24 AM
Lourencosampaio Lourencosampaio is offline
Rep: 10 Posts: 6
What defines performance?
Can anyone tell me what are the main points that define performance of a sailing boat please?
Old 09-20-2009, 09:50 AM
alan white's Avatar
Rep: 1168 Posts: 3,269
Performance normally means "how the boat sails". How does it sail to weather? How fast? How is the boat in light air or when caught out in a bad storm?
If a boat does well in most of those areas it is considered to be performing well, and if it fails to deliver it is performing poorly, though the boat may well be doing very well in other areas such as comfort and safety.
I think performance is only about what could be noted from a distance by another sailor. It has nothing to do with what hardships, for example, were sustained in achieving that performance. For that reason, performance is only one of many factors that make for a desirable sailboat.
Old 09-20-2009, 09:52 AM
bistros bistros is offline
Previous Member
Rep: 0 Posts: 534
This is a very broad topic, and what defines performance for one boat type is not necessarily relevant for another. Before anyone can provide you with a clear answer, you would have to narrow the criteria down enough to allow a sensible response.
Some general groups:
  • displacement dinghies
  • planing dinghies
  • foiling dinghies
  • planing keel boats
  • displacement keel boats
  • drop keel yachts
  • ice yachts
  • catamarans
  • cruising yachts
  • motor sailors
  • trimarans
Each of these groups can be further divided in many subgroups. Each has it's own "idea" of performance.
In general, speed is important, pointing ability is important and the ability to sail well in the design conditions is important. A scow is a fast planing boat designed for inland lakes and flat water. A scow performing exactly as designed would be a poor performer in exposed sea conditions with waves and chop. A great rough sea performing boat would not be able to keep up with fast planing dinghies in flat water.
I hope this response helps you look further into your question and cause thought.
Bill
Old 09-20-2009, 10:12 AM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,267
saw a big tree poster once with a heading "what is strength"
than some more text and bottom line was it was advertising for zippers
but yes, as explained and want to add its a pitty often only racers get the glory
Old 09-20-2009, 10:47 AM
Rep: 2891 Posts: 8,789
The performance of any sailing yacht is wholly governed by the desires of the original commissioning clients. This rarely is fully understood by those other then the designer and clients. Subsequent renditions of the same design will display these attributes, but understanding the compromises necessary to achieve them, will be missing from the equation.
In other words, the question "What defines performance" is subjective and imposable to describe, without the designer's input about the convoluted concessions and compromises made during the design's development.
Old 09-20-2009, 01:01 PM
Member
Rep: -33 Posts: 951
Performance in a "Pleasure " boat is the ratio of output of pleasure to the input of displeasure ( work , expense, time on the treadmill, etc.)
Brent
Old 09-20-2009, 05:49 PM
The P/D ratio (Pleasure/Displacement) Brent or is this a formula, like displacement divided by pleasure . . .
Old 09-21-2009, 12:08 AM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 338
• center of gravity. If its tippy, you can't get a lot of power out of its sail plan.
• Displacement. lighter is typically faster in any vehicle.
• Hull shape, some hulls go through the water easy, some not so easy.
• Keel shape. Keels are the "wing" that makes sailing to weather possible.
• Sail shape. Poor sail shapes kill boat speed.
Is this the kind of list you are looking for?
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Old 09-23-2009, 06:40 PM
Member
Rep: -33 Posts: 951
Performance
No it has nothing to do with displacement, other than displacement of your free time to persue consumerism's , "Keep up with the Jones's" priorities.
Brent
Old 09-23-2009, 07:19 PM
bntii's Avatar
bntii bntii is offline
Rep: 943 Posts: 636
Performance?
As in to perform a task well??
Define the task and study a number of designs to see which is best suited to this task...
Or is this the 'performance' car vs the family sedan?
The performance boat in this case is just faster & designed well enough to find its way through wind and waves while keeping its speed.
Old 09-28-2009, 01:08 PM
BeauVrolyk's Avatar
BeauVrolyk BeauVrolyk is offline
Sailor
Rep: 153 Posts: 160
Once again, this is like the question:
"How long is a piece of string?"
It doesn't have an answer. You have to say what sort of performance you're looking for. Options include:
1) Speed
2) Pointing to windward
3) Planing down wind
4) Ability to carry a large gang of friends while drinking in comfort
5) Ability to tow a waterskier
As you can see, there are a lot of types of "performance". Once you define it, then we can tell you what sort of things measure that "type" of "performance".
Good hunting,
BV
"Anything worth doing is worth doing to excess"
Old 09-28-2009, 07:17 PM
Mariner
Rep: 777 Posts: 1,543
What is performance in a sailboat?
Getting what you want from it.
I suppose the next question could then be:
"What performance qualities do you look for in a sailboat."
To which I would respond: "It depends, why do you ask?"
Tom
Old 10-01-2009, 07:53 AM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 318 Posts: 496
Completely agree with Brent Swain, because "the main purpose of yacht is to pleasure her owner"...
Old 10-01-2009, 07:54 PM
Member
Rep: -33 Posts: 951
Step one in defining efficiency in anything is to first define what you are trying to accomplish. Performance can then only be defined in it's effectiveness in achieving that goal.
Brent
Little RIB performance. corsair.p Boat Design 4 09-17-2007 10:03 AM
Want more speed and performance!!!!!! MarioCoccon Sailboats 9 08-23-2006 04:38 PM
Performance prediction ? fcfc Boat Design 1 10-29-2004 10:09 AM
Prop performance danmarine Boatbuilding 0 05-20-2004 01:58 PM
Prop performance danmarine Fiberglass and Composite Boat Building 0 05-19-2004 07:03 AM
