Old 06-08-2005, 08:43 PM
dylnsprts dylnsprts is offline
Rep: 10 Posts: 8
what is the best type of sail for the money?
i am looking to buy new sails. however i don't want to spend a ridiculous amount of money and have to buy new sails every month. so what would you recomend to a racer who is willing to spend the money as long as it is worth it and will last(i am talking about the main, jib and spinaker).thanks.
-dylan
Old 06-08-2005, 09:16 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Dylan,
What kind of boat?
Yokebutt.
Old 06-08-2005, 09:19 PM
Rep: 10 Posts: 8
a merit 25
Old 06-08-2005, 09:38 PM
usa2's Avatar
usa2 usa2 is offline
Rep: 11 Posts: 538
are you looking for serious racing sails, or something that will last at a marginal sacrifice in performance?
Old 06-09-2005, 03:33 PM
Rep: 2891 Posts: 8,798
It depends on what part of the fleet you want to be in at the finish. If you want to be in the front of the fleet, you'll likely have to opt for sails that stretch and break down from UV quicker then the sails the middle of the pack will use. If you sip wine and eat cheese as you round the marks, then a good set of cruising sails may will suit you, but expect to be at the back of the bunch.
Old 06-09-2005, 04:11 PM
Rep: 10 Posts: 8
i want to be inbetween the middle to the front
-dylan
Old 06-09-2005, 04:12 PM
Rep: 10 Posts: 8
they will be racing sails the problem is which type
-dylan
Old 06-09-2005, 04:18 PM
usa2's Avatar
Rep: 11 Posts: 538
Quantum, North, and Doyle make good sails if you want a brand name sail. There are many small (local) lofts in the US that are using Cuben fiber to produce very efficient, light sails. I am not sure about pricing for anything except that North Sails will probably charge more comparitively than Quantum or Doyle. Doyle and North have the best customer service-generally.
Old 06-09-2005, 04:19 PM
usa2's Avatar
Rep: 11 Posts: 538
are you looking for paneled sails or one-piece "loadpath" sails.
Old 06-09-2005, 07:21 PM
Rep: 10 Posts: 8
what is the difference?
-dylan
Old 06-09-2005, 07:41 PM
usa2's Avatar
Rep: 11 Posts: 538
paneled sails are made up of panels of sail cloth sewed together, while the one-piece "loadpath" sails are sewed and laminated together to form a almost perfectly smooth airfoil. Most racers use loadpath sails. Doyle D4 is a very good type of sail, North's 3DL and Quantum's Fusion Membrane are also very good.
Old 06-09-2005, 07:58 PM
astevo astevo is offline
Rep: 10 Posts: 69
load path = high price... very good sexy looking sails ut expensive. your best bet is too look at a sailmaker who has made stuuf you the merit before and performed well. If you cant find one, maybee look at someone who has made sails for similar boats.
go for a good quality panneled sail and it will be fine. are you racing phrf or onedesign????
Old 06-10-2005, 09:20 AM
Boatbuilder
Rep: 15 Posts: 545
Dylan,
Cross-cut dacron main and a 3/4oz nylon spinnaker should work fine on that size boat, if you want to use more advanced materials, reserve those for the headsails. This all depends on the conditions you normally sail in, if it's typically light air, you can put more money into the genoa #1 and get a cheaper #3. Of course, you can also buy less expensive headsails and get a 1/2oz spinnaker for when the 3/4 is too heavy to fly.......
Yokebutt.
Old 06-10-2005, 09:29 AM
Seafarer24 Seafarer24 is offline
Sunset Chaser
Rep: 22 Posts: 203
How about a Pentax main sail? I'm not sure what the stay arrangement is on your boat, but I'm assuming a square-top is out of the question? Fully-battened is a given, in which case you'll need to have the shop sell you battens that work best with that sail (likely to be foam). How bendy is your mast?
Old 06-10-2005, 02:56 PM
usa2's Avatar
Rep: 11 Posts: 538
Ive sailed on a boat with Spectra sails, they seemed to work well. Yokebutt is right about reserving the more exotic materials to headsails, as you want your main to last a long time.
Sail Loading on Rig, Rig Loading on Vessel brian eiland Sailboats 93 02-23-2011 08:19 PM
Anyone familiar with Powerfoil sails? Mark Neill Sailboats 12 12-17-2008 11:07 PM
Why does a cutter rig point higher & sail faster? Rich Kinard Sailboats 140 08-20-2008 07:43 PM
Loose footed mains Polarity Sailboats 65 09-14-2007 05:37 PM
