Old 04-03-2010, 02:49 PM
Serinity Serinity is offline
water in the bilge
I have a1991 Hunter 37.5 which I just purchased. In survery there wasn't any water in the bilge. Now after living aboard for 3 weeks there is a small amount of water which I cleaned out last night only to find it reappearing today. It's doesn't appear to be coming for forward or aft just in the center around the large bolts which proturde up through the hull. Does anyone know where it may be coming from?
Old 04-03-2010, 02:54 PM
Rep: 1493 Posts: 7,447
Spray talcum (baby) powder on the sides of the bilge and if it is coming form above you will se the trails. Living aboard causes a lot of condensation. It may just be that.
Old 04-04-2010, 07:35 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
A surveyor suggested to me using dry erase markers to see where the water is coming from. I thought it was a great idea.
Tom Speer
Old 04-04-2010, 08:10 PM
alan white's Avatar
alan white alan white is online now
Rep: 1211 Posts: 3,325
Make sure the ice box isn't draining into the bilge---- some do. Pour some Kool Ade or something down the drain hole at the bottom of the box.
Old 04-06-2010, 06:32 AM
kenJ kenJ is offline
Rep: 56 Posts: 333
Leaks
I have found the koolaid works better than the dry erase. Make a small trail around the top of the bildge.
If you have a keel stepped mast some rain will wick it's way down the mast with every rain shower. Comes in around the sheaves and other halyard holes in the mast.
Don't forget to check your prop stuffing. If you moved the boat after it sat for a long period it might require tightening.
Was it in the water when you purchased it? If it was on the hard, then perhaps you have a small leak where the keel attaches, those are the big bolts you see. Doubtfull though, a good surveyor would have found that.
Old 04-07-2010, 06:34 AM
Rep: 56 Posts: 333
Does your fresh water pump cycle even though you are not using the water? If yes you have a leak somewhere on the pressure side of the fresh water system. Also check the supply side, a leaking inspection port or loose connection will also supply a trickle of water to the bilge
Bilge taking on water ziola Sailboats 5 10-28-2009 05:55 PM
Frozen water in bilge.. Adrian2 Boat Design 4 03-11-2007 10:59 AM
water in bilge of old boat llwjrw03 Fiberglass and Composite Boat Building 0 12-27-2005 07:20 AM
Newbie Question- Water in Bilge indy Powerboats 2 07-06-2005 08:55 AM
Water in bilge liloldham Powerboats 8 07-23-2004 08:37 AM
