Old 07-27-2008, 07:38 AM
haaho haaho is offline
Rep: 10 Posts: 2
Water ballast sail-boat?
Hi, I am looking for plans for a 24-28 f sail boat, with daggerboard and a water ballast system as a main ballast.
My idea is the boat to be light for trailering, and to use diferent weight daggerboards for calm lakes and sea. I saw in internet a boat which was class B or C depends on the keel waight.
I appreciate any help.
excuse my English.
Old 07-27-2008, 04:26 PM
Rep: 457 Posts: 1,404
water ballasted skimmer
Here is my 5.5 x 2.25 metre Cox's Bay Skimmer -a trailerable lightweight dayboat with two mean bunks under the forward cockpit sides, two 6.5 metre wing masts in schooner rig, - design could easily be enlarged to 7 metres or so.
Water ballast sail-boat?-copy-skimmer2.jpg  Water ballast sail-boat?-copy-skimmer3.jpg  Water ballast sail-boat?-img_1144.jpg
Old 07-27-2008, 05:59 PM
Doug Lord
Gary, is there something under the water on that boat that I might find interesting?! Cool design!
Old 07-27-2008, 07:54 PM
Munter Munter is offline
Amateur
Rep: 100 Posts: 223
Check the internet for details of designs by Jim Young. He designed a few water ballasted trailerables a while back.
Cole 43 Rumrunner II - An Australian classic
My home efficiency/renovation blog
Old 07-27-2008, 11:30 PM
skimmer
Nothing special Doug, in fact very basic, just a good shaped dagger and transom hung rudder - the boat is for an architect friend. The original design had two asymmetric daggers that angled out a few degrees from the turn in the bilges, even that now is commonplace with IMOCA and other designs, but of course no lead keel. But two boards require shifting every time you tack and I decided to keep this boat simple. The water ballast will only be used in heavier wind conditions. Rig is low but of large area. Hoping for 120 kgs all up?
Old 07-28-2008, 06:18 AM
rwatson's Avatar
rwatson rwatson is online now
Rep: 1188 Posts: 2,401
28ft water ballast
I am getting one designed at the moment - 28ft, water ballast, twin keels, but also with an outboard option.
Just had the stability calcs done.
The first draft is attached for your info -
Inspiration is drawn from the Mac26, but with self tacking, inspection hatches on the water ballast to put in lead ballast for heavy weather, and to maintain fresh water bladders.
I am looking forward to 500 litres of fresh water on a 28footer - showers every day for a fortnight.
I am also having an internal nav station for heavy weather motoring with the 75hp outboard.
Old 07-28-2008, 08:49 AM
Rep: 10 Posts: 2
Very nice RWATSON, thats exactly my idea. When will it be ready. Tell us more about the lead ballast for heavy weather. Can't you just use different daggeboards?
The 75 hp is too much for me , I am thinking around 10 hp.
Old 07-28-2008, 05:37 PM
75 hp?
Surely a typo RWatson? If not, why are you bothering with sails?
Old 07-28-2008, 09:02 PM
rwatson's Avatar
No - 50-75 hp range is correct, like the Macgregor 26 . Will do around 20 knots with a bit of luck
Sails are for low cost, fun racing, motor is for emergencies, getting to the sailing area or across potentially hazardous stretches quickly and zero or too much wind.
The inspection hatches on the water ballast will be placed so that epoxy covered lead ingots can be placed amongst the baffles, in case I want to attempt some offshore exploration.
Bit more info on the concept at
rough draft of 28ft trailer/sailer/power cruiser with water ballast
Different daggerboards is a great idea. Normally they will be hollow to allow water inside. I will build an extra inlet at the top hole where I could pour leads shot in. Mind if I use the idea?
I am expecting the DXF files for cutting within 8 weeks, after the sailplan and ballast locations are confirmed.
After 18months of frustration, and over $5000, I finally have a designer that is 'in sync' and available.
Now - what to build it of ........... ??
I think the first prototype will be ply, then one in alloy.
water jet propulsion in a sail boat Multi600 Jet Drives 1 03-31-2009 05:09 PM
Water Ballast & Keel Ballast jag459 Sailboats 4 09-08-2005 01:39 PM
Water Ballast vs Keel Ballast jag459 Boat Design 13 09-08-2005 07:01 AM
water ballast sail boats cnac Sailboats 2 11-12-2004 05:25 AM
Water Ballast Guest Boat Design 17 09-30-2003 01:50 AM
