Old 07-26-2004, 02:22 PM
tranmkp tranmkp is offline
Rep: 28 Posts: 86
Wanker 36 stability curves, understanding
just what they mean. For the example, is this a boat suitable for offshore racing? What catagory would this curve fall into? That would be a big help.
Old 07-26-2004, 07:15 PM
mistral mistral is offline
Rep: 22 Posts: 154
just few words on a very wide argument:
considering the "about sinusoidal" curve:
-the initial slope will tell how stiff is your boat; the steeper the curve the stiffer is your boat on little angle of heeling
-the Y-axis value on 30 degrees of heeling RM30 is traditionally considered as the projecting value to dimension the mast section
-the peak of the curve is the maximum righting moment of your boat
-the angle (approx 115 degrees, i guess) at wich curve came back to y=0 represent the angle of vanishing stability. Assume that your boat is knocked down by a wave, this would be the widest angle at wich you may hope that your boat recover to unheeled position by herself; at wider angle your boat will capsize.
-the area under the curve from 0° to 115° is the amount of energy required to capsize your boat, or, on the other side, your reserve of total stability
-the area from x-axis and lower part of the curves (from 115° to 180°) is the amount of energy required to restore your boat from a capsize.
A great book to understand this argument is "seaworthiness: a forgotten factor", by Tony Marchaj, very good and wide explanation of phenomenon but somehow anti-historical conclusion (just in my opinion of course ).
To spent some words on specific boat, generally speaking (i don't know the boat) I would expect a wider angle of vanishing stability for a 36' offoshore racer, 115° is not a huge value, and even most disappointing is the maximum negative value (at 155° heeling), this means than this boat is quite stable when capsized, it means that it's difficult that a wave can recover her after a capsize
fair wind
mistral
Incredible "Secrets of Yacht Design" website located... pkoken Sailboats 579 10-09-2005 08:33 PM
Understanding Stability and Trimming Calculations Brian Boat Design 0 07-27-2004 02:38 AM
Sailboat stability... ErikG Boat Design 7 11-30-2003 12:53 PM
